Mail Flow - External Message Warning HELP
2019-02-11T17:13:35+00:00
Hello!
I'm trying to setup a mail flow rule for external email messages from non-organization addresses. I have it setup great, however I have it coded so that it displays the yellow background, red boarder etc and it displays perfect in a sample code viewer. However, when I add it to my rule and then send a test message to my email from outside the org, it doesn't display any of these colors. HELP?? I have included my code below. I'm using 0365
<div style="background-color:#FFEB9C; width:100%; border-style: solid; border-color:#9C6500; border-width:1pt; padding:2pt; font-size:10pt; line-height:12pt; font-family:'Calibri'; color:Black; text-align: left;"><span style="color:#9C6500"; font-weight:bold;>CAUTION:</span> This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.</div><br>
2019-02-11T19:26:52+00:00
Hi BH33,
Thanks for provide the details in your post. About your question, please kindly check following steps to see if it can help you fix this issue:
  1. In Exchange Admin Center, go to mail flow > rules and then click "+" to create a new rule.
  2. Then set the new rule like below picture:
Note: in step 4, please enter following code:
<p><div style="background-color:#FFEB9C; width:100%; border-style: solid; border-color:#9C6500; border-width:1pt; padding:2pt; font-size:10pt; line-height:12pt; font-family:'Calibri'; color:Black; text-align: left;"><span style="color:#9C6500"; font-weight:bold;>CAUTION:</span> This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.</div><br></p>
I have tested above rule on my side and I can successfully show the warning message(see below picture), if you have any problems when doing so, please feel free to post back and provide us a screenshoot of the detailed information about the rule you created for analysis.
Regards,
Jennifer
93 additional answers
    2020-01-13T14:20:28+00:00
    Going a step forward, could be great if there's an option of include received Plain Text emails or another way round: convert any incoming Plain Text email to HTML.
    Is it that possible?
    Rgds,
    ES
    2020-01-22T15:17:35+00:00
    Thank you this was very helpful.
    2020-01-23T19:57:17+00:00
    This worked great for me. but when a message comes in it duplicates the Banner.  I cut and pasted the txt from above.  Any comments.
    2020-01-30T19:38:15+00:00
    ASGAU,
    This is HTML code. At the end of your banner add a line break or however many you need.
    A line break is just <br>
