Mail Flow - External Message Warning HELP
2019-02-11T17:13:35+00:00
Hello!
I'm trying to setup a mail flow rule for external email messages from non-organization addresses. I have it setup great, however I have it coded so that it displays the yellow background, red boarder etc and it displays perfect in a sample code viewer. However, when I add it to my rule and then send a test message to my email from outside the org, it doesn't display any of these colors. HELP?? I have included my code below. I'm using 0365
<div style="background-color:#FFEB9C; width:100%; border-style: solid; border-color:#9C6500; border-width:1pt; padding:2pt; font-size:10pt; line-height:12pt; font-family:'Calibri'; color:Black; text-align: left;"><span style="color:#9C6500"; font-weight:bold;>CAUTION:</span> This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.</div><br>
2019-02-11T19:26:52+00:00
Hi BH33,
Thanks for provide the details in your post. About your question, please kindly check following steps to see if it can help you fix this issue:
  1. In Exchange Admin Center, go to mail flow > rules and then click "+" to create a new rule.
  2. Then set the new rule like below picture:
Note: in step 4, please enter following code:
<p><div style="background-color:#FFEB9C; width:100%; border-style: solid; border-color:#9C6500; border-width:1pt; padding:2pt; font-size:10pt; line-height:12pt; font-family:'Calibri'; color:Black; text-align: left;"><span style="color:#9C6500"; font-weight:bold;>CAUTION:</span> This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.</div><br></p>
I have tested above rule on my side and I can successfully show the warning message(see below picture), if you have any problems when doing so, please feel free to post back and provide us a screenshoot of the detailed information about the rule you created for analysis.
Regards,
Jennifer
93 additional answers
    2021-03-31T19:22:19+00:00
    Here is the what I am using for my rule and the background and border color do not appear.. Screenshot provided as well.
    <p><div style=border-color:# 9C6500; background-color:#FFEB9C; padding:1em;> <span style=font-size:12.0pt;color:black;><b>[EXTERNAL EMAIL]</span></b> <span style=font-size:10.0pt;color:black> CAUTION: This email originated from outside of the organization. DO NOT CLICK links or open attachments unless you recognize the sender and know the content is safe.</span></p>
    2021-04-05T21:37:57+00:00
    I'm not an HTML guru, but I believe your syntax is incorrect, no space between # and your number, missing "", also your not putting a border around, just telling what the border color should be.
    2021-04-22T18:22:12+00:00
    I am getting no background colour or border. Just the text.
    2021-04-30T16:04:31+00:00
    Hi William and Tom,
    Have y'all tried sending yourself something more elaborate than "hello"?  I noticed this issue this morning, and in troubleshooting it seems that if I just send simple text, it gets formatted as such and I only get the unformatted warning text. But if I do something like a bolded "hello", it gets sent as HTML and the receiving client formats the warnings correctly.
