A group of Microsoft Products and technologies used for sharing and managing content, knowledge, and applications.
Hi Jeff,
To narrow down the issue, you can follow the steps below to check whether the file require to be checked out before it can be edited.
- Go to the SharePoint library, click settings icon > Library settings.
- Click Versioning settings under General Settings.
- Check whether you have chosen Yes in Require Check Out. If yes, please choose No and check the result.
Regards,
Tisky
