Excel 2016 Mac Problem Bug Linking Cells Between Worksheets
2017-03-27T00:15:55+00:00
I have multiple worksheets in my excel document. I am trying to link data from a cell on worksheet 2 to a cell on worksheet 1. I enter "=" in the cell on Worksheet 1 and then click on Worksheet 2 and go to the cell that I want to reference/link. When I click on it, nothing happens in the cell on Worksheet 1. Yet the formula appears on a random cell in Worksheet 2. I have had no problem doing this before and the same workbook/document has multiple inter-sheet links from previous work I have done on it. All of a sudden this problem started happening today. Please help me figure this out. Very frustrating. Thank you. Brad.
2017-04-18T03:45:46+00:00
Hi Everyone,
I’d like to make a summary about this case, so other community members who come across this thread will easily find the useful information:
Issue description:
The formula/value will be in a random cell after linking cells between worksheets when you store the workbooks in Dropbox.
More information:
Original, we have identified the issue will disappear when we go to the Dropbox settings and set the Dropbox badge to "Never show"..
Now, the issue should have gone away. It seems that the issue has been fixed by Dropbox in their latest release. For more information, refer to:
https://www.dropboxforum.com/t5/Sharing-and-collaboration/Issue-with-Excel-files/m-p/213012#M13803
Disclaimer: Microsoft provides no assurances and/or warranties, implied or otherwise, and is not responsible for the information you receive from the third-party linked sites or any support related to technology.​
If you have any other questions, feel free to start a new thread and we will keep assisting you from there.
Regards,
Sky
51 additional answers
    2017-04-12T16:25:28+00:00
    Hi all - Thanks again for all the attention to this issue.  You should be able to avoid this issue by disabling the  Dropbox badge.  We are still investigating the root cause, so I don't know how this will finally be resolved, but you can workaround it for now.
    To disable it, go to the Dropbox settings and set the Dropbox badge to "Never show".
    2017-04-11T21:18:43+00:00
    In my experience, this problem only happens with files stored on Dropbox. Is that the same for everyone else?
    2017-03-28T01:47:19+00:00
    Hi Brad,
    Please let us know your updates at your convenience if you need further help.
    Cliff
    2017-03-27T02:52:54+00:00
    Hi Brad,
    Please confirm if you have tried this. If no, try this to see the outcome.
    a. Click on the cell in Sheet1.
    b. Click Insert>Hyperlink>Document>type the cell you want to link in Sheet2.
    Meanwhile, provide us with the following.
    a. The detailed reproducing steps of the issue you are experiencing.
    b. Some screenshots related to the symptom of the issue.
    c. A full screenshot showing the version information of Excel 2016 for Mac via File>Account.
    Cliff
