Some images in Publisher 2016 not displaying
2017-03-02T16:20:07+00:00
Hello all,
Since yesterday, some images in my Publisher publications DO display correctly as they normally do, but some now do NOT display at all!?!  I can see their boundaries, but can't see the images themselves!?!  If I resize them to something bigger, they display correctly, but when I make them smaller/to their original size, they disappear!?!
I've searched around and tried a lot of things, but can't seem to find any good answer...
The images themselves are all embedded in the file and I repeat, displayed perfectly until I shut down my PC yesterday.  When I booted back up and reopened the same file, this problem came up.
If I reinsert images, they show up correctly!?!  I have thousands of images in those files, so cannot resort to reinserting them one by one!
Any idea?  Thanks in advance for your help!
P.S  I am running the most current version of Office 365 for business (Office 2016), version 1701 build 7766.2060... did an Office update happen when I booted back up yesterday causing this problem, I do not know because I can't seem to find any update history :-(
2017-03-11T06:46:28+00:00
Hi Amy,
The new Office version 1702 (Build 7870.2020) was released to Current Channel on March 9, 2017. You may try it in Current Channel as the issue has been fixed in this version.
For other Channels, you may monitor and check the updates in the following article.
Version and build numbers of update channel releases for Office 365 clients
Felix
2017-03-08T07:10:25+00:00
Hi All,
We are summarizing the symptom here:
Description
Some images become blank white shape in Publisher 2016.
Environment
Publisher 2016 (Current Channel, Version 1701, 7766.2060)
More information
We checked the issue can be fixed in the future Office update (Version 16.0.7766.2068, and 1702, 7870.2020). You can just wait for the update, or use the current workaround, or contact your IT admin to check if you can get the First Release build of Office.
Current Workaround
Revert to an earlier update using ODT: officec2rclient.exe /update user updatetoversion=16.0.7571.2109
To check more details, please refer to this article.
 [Updated by Jim Liu MSFT,  10:00 AM, Mar 9 , 2017 (UTC)]
Jim
51 additional answers
    2017-03-04T11:14:41+00:00
    Hi Jack007WT,
    Can you confirm if you did the steps from Rena? Also, can you provide a screenshot of the issue as well as the steps you did on how you encounter it?
    Check if you have the latest updates for your Office application. To verify, go to File > Accounts and then Update now. Provide the current version after you update.
    Also, does this happen on a specific file? Can you provide the file for our review? To protect your privacy, I have sent you a private messag to collect the file and can be accessed on this link: https://answers.microsoft.com/en-us/privatemessages/list
    Mike
    2017-03-04T15:18:47+00:00
    I would suggest that you look at what 'patch' from MSFT created this problem with Publisher as the OP's problem is not unique.
    Here are three other posts with the same problem, all just after the first of the month:
    https://answers.microsoft.com/en-us/msoffice/forum/msoffice_publish-mso_win10/publisher-photos-issue/1ff627a7-001f-4d18-8f72-cbd0f99857f2
    https://answers.microsoft.com/en-us/msoffice/forum/msoffice_publish-mso_other/cant-see-photos-in-my-publisher-files/b5d8dd6a-7158-437c-b203-9f88a3452db4
    https://answers.microsoft.com/en-us/msoffice/forum/msoffice_publish-mso_win10/pictures-dont-appear-in-publisher-2016-document/fa4f4407-52e9-4d3b-9af1-b119ad2af336
    Publisher 2016 and to a lesser degree, Publisher 2013 have been choking on pictures, especially high resolution, large file size images, in one way or the other since they were introduced. It was as of Pub 2013 that MSFT took away the picture display option to 'Fast resize and zoom' and left only 'detailed display' and 'hide pictures'. Pub 2010 and older had no problem rendering image intensive Pub files. These same files started choking in Pub 2013 and 2016 and frequently ended up with the inserted images not displaying or even the whole file going corrupt.
    If the OP does provide you with his working file I suggest you try opening it with Pub 2010 or even Pub 2007 with the 'Fast resize and zoom' picture option checked and I expect it would open just fine.
    I don't know if this will lead to a solution for Pub 2016 users but as I said before MSFT removed the 'Fast resize and zoom' option there was no problem inserting large file size, high resolution images into a Pub file. Perhaps this fact will lead to a solution for how Pub 2016 was broken with your last 'patch' and hopefully a long term solution.
    DavidF
    2017-03-04T19:43:26+00:00
    Mike,
    Here are my answers w/regard to Rena's suggestions/questions for Philippe -
    1. The picture came from my computer, not the Internet.  And I would usually 'copy & paste' it (.JPG file at 109KB) to every new project item within the same file.
    2.  I only found this fix-it thread, as of 3/3/2017.
    3.  Yes, the issue of 'no photo image being displayed' occurs in all of my 8 files & when I 'save-as' file #8 the issue was still evident.
    4.  Here is a screenshot of the correct image being displayed (my OK2BG logo in the lower right-hand corner) when I print the file -
    (As I mentioned in my previous response - When I go to View > Graphics Manager > (locate one of the images not displaying & click the side toggle) > Details // The .jpg image displays there, okay.)
    1. Here is a screenshot of the image not displaying in my file -
    And you can see that all the images are blank in the mini-icons of my 7 other postcards on the left-side panel, except for the last one on the bottom, which I just added to see if it might also disappear at some point.
    1. I will send you a copy of the problem file via your private message board.
    To your questions -
    1. The steps I took when I first encountered the problem was that I simply opened the file & there it was, or was not.  As I mentioned in my previous thread, the only other different thing I did before I closed the file was to make/print pdf files of each postcard.
    2. I checked for Office updates (inside Publisher) & it said 'You're up to date! - The latest version of Office is installed on your computer' at these coordinates - File > Account > Office Updates > (toggle for) 'Update Now'
    I thought I read somebody's suggestion about checking recent updates -
    When I check for any recent updates at - Control Panel > (type 'updates' in the Search Field) > Programs & Features > View installed updates > there were only 2 recent updates on 2/22/2017 w/regard to a Security Update for Adobe Flash Player & an update for Adobe Acrobat Reader DC.
    1. I have Windows 10 > Microsoft Office Home & Business 2016 aka Publisher 2016 version 16.0.7766.2060 installed on 3/3/2017 (not sure what that date means, maybe a hidden update?!)
    Other than that...I still like Publisher, but am hesitant to do any further work in my files and/or I do not want to replace all 500 of the errant images across all my file/projects.
    I will wait to hear from you.
    Thanks!
    Jack
