Some images in Publisher 2016 not displaying
2017-03-02T16:20:07+00:00
Hello all,
Since yesterday, some images in my Publisher publications DO display correctly as they normally do, but some now do NOT display at all!?!  I can see their boundaries, but can't see the images themselves!?!  If I resize them to something bigger, they display correctly, but when I make them smaller/to their original size, they disappear!?!
I've searched around and tried a lot of things, but can't seem to find any good answer...
The images themselves are all embedded in the file and I repeat, displayed perfectly until I shut down my PC yesterday.  When I booted back up and reopened the same file, this problem came up.
If I reinsert images, they show up correctly!?!  I have thousands of images in those files, so cannot resort to reinserting them one by one!
Any idea?  Thanks in advance for your help!
P.S  I am running the most current version of Office 365 for business (Office 2016), version 1701 build 7766.2060... did an Office update happen when I booted back up yesterday causing this problem, I do not know because I can't seem to find any update history :-(
2017-03-11T06:46:28+00:00
Hi Amy,
The new Office version 1702 (Build 7870.2020) was released to Current Channel on March 9, 2017. You may try it in Current Channel as the issue has been fixed in this version.
For other Channels, you may monitor and check the updates in the following article.
Version and build numbers of update channel releases for Office 365 clients
Felix
2017-03-08T07:10:25+00:00
Hi All,
We are summarizing the symptom here:
Description
Some images become blank white shape in Publisher 2016.
Environment
Publisher 2016 (Current Channel, Version 1701, 7766.2060)
More information
We checked the issue can be fixed in the future Office update (Version 16.0.7766.2068, and 1702, 7870.2020). You can just wait for the update, or use the current workaround, or contact your IT admin to check if you can get the First Release build of Office.
Current Workaround
Revert to an earlier update using ODT: officec2rclient.exe /update user updatetoversion=16.0.7571.2109
To check more details, please refer to this article.
 [Updated by Jim Liu MSFT,  10:00 AM, Mar 9 , 2017 (UTC)]
Jim
51 additional answers
    2017-03-15T15:38:08+00:00
    I had this problem and was told to update Publisher.  Within Publisher it says I am up to date.  I opened Word and there was an update for Word and Outlook.  After I did that update Publisher worked correctly even though it did not mention Publisher as part of the update.
    2017-03-15T17:06:46+00:00
    My problem was also fixed after I did a (forced) Office update via Publisher, at -
    File > Account > Office Updates > Update Options > Update Now
    Be sure to click the 'continue' button on one of the screens, even tho it looks like it's running, otherwise it won't proceed to the end, which I discovered when I left it running all night because I thought it needed more time to run.
    But all's well that ends well!
    Thanks!
    Jack
    2017-03-17T15:09:47+00:00
    I am having issues with pictures showing up in Publisher after the last update. Tif files will not show up at all and some jpg. I do a lot of work with this program and a lot of editing with the program, so this is a major inconvenience. I need this fix a.s.a.p.
