Some images in Publisher 2016 not displaying
2017-03-02T16:20:07+00:00
Hello all,
Since yesterday, some images in my Publisher publications DO display correctly as they normally do, but some now do NOT display at all!?!  I can see their boundaries, but can't see the images themselves!?!  If I resize them to something bigger, they display correctly, but when I make them smaller/to their original size, they disappear!?!
I've searched around and tried a lot of things, but can't seem to find any good answer...
The images themselves are all embedded in the file and I repeat, displayed perfectly until I shut down my PC yesterday.  When I booted back up and reopened the same file, this problem came up.
If I reinsert images, they show up correctly!?!  I have thousands of images in those files, so cannot resort to reinserting them one by one!
Any idea?  Thanks in advance for your help!
P.S  I am running the most current version of Office 365 for business (Office 2016), version 1701 build 7766.2060... did an Office update happen when I booted back up yesterday causing this problem, I do not know because I can't seem to find any update history :-(
2017-03-11T06:46:28+00:00
Hi Amy,
The new Office version 1702 (Build 7870.2020) was released to Current Channel on March 9, 2017. You may try it in Current Channel as the issue has been fixed in this version.
For other Channels, you may monitor and check the updates in the following article.
Version and build numbers of update channel releases for Office 365 clients
Felix
2017-03-08T07:10:25+00:00
Hi All,
We are summarizing the symptom here:
Description
Some images become blank white shape in Publisher 2016.
Environment
Publisher 2016 (Current Channel, Version 1701, 7766.2060)
More information
We checked the issue can be fixed in the future Office update (Version 16.0.7766.2068, and 1702, 7870.2020). You can just wait for the update, or use the current workaround, or contact your IT admin to check if you can get the First Release build of Office.
Current Workaround
Revert to an earlier update using ODT: officec2rclient.exe /update user updatetoversion=16.0.7571.2109
To check more details, please refer to this article.
 [Updated by Jim Liu MSFT,  10:00 AM, Mar 9 , 2017 (UTC)]
Jim
51 additional answers
    2017-03-08T15:34:10+00:00
    Hi Mark,
    Have you tried the workaround Jim provided above? If it persists after the workaround, the cause for the issue may be different. Given this situation, I would like to suggest you create a new thread in this forum, so we can handle it separately.
    @Philip, Amy
    We will update here if the Office update is released. You can just wait for the update, or use the current workaround, or contact your IT admin to check if you can get the First Release build of Office.
    Regards,
    Yoga
    2017-03-08T16:53:44+00:00
    Hi Yoga,
    Is this release to happen in the new few days? Or are we looking at weeks or months away? I understand you can't give me a specific date, but at least a general idea of when is needed.
    It would be helpful to know to make a decision for customers to take the time & effort to revert back or to do our own work-arounds until the fix is released.
    Please help us understand when this release is expected.
    Thank you,
    Amy
    2017-03-08T21:20:37+00:00
    This is the same problem I posted on February 9, 2017 after the update to version 1701, 7766.2047.
     Publisher 2016 not displaying TIF images
    Version 1702, 7870.2020 appears to resolve this issue.
