Cut/Copy and Paste Problems in PowerPoint
2013-09-30T02:03:09+00:00
PowerPoint will not allow me to paste anything into a slide.  I have tried text into a text box, shapes, entire slides.  It allows me to copy or cut, but when I try to paste it is greyed out or does nothing when I use Command+V on my MacBook Pro.  I am running Office 2011 Home & Student and copy and paste work fine in Word and Xcel.  I have tried to reinstall the software and that didn.t help either... Any ideas?
71 additional answers
  1. Jim G 134.1K Reputation points MVP
    2014-05-16T16:05:41+00:00
    Just to summarize...
    The clipboard is an interaction between PowerPoint and Mac OS X. There seems to be a problem on certain Macs using the clipboard in PowerPoint but not other applications. The symptoms persist even after performing the following actions:
    1. Try making a new user account in Mac OS X preferences. Log into the new user account. The problem persists even in the new user account, which lets us rule out bad PowerPoint preference files as potential source of the trouble.
    2. Try using PowerPoint after doing a Safe Boot. This rules out the source of the problem being due to any of the many things affected when you do a safe boot, including having a messed up font cache.
    3. Reinstall Office after first completely removing Office. Be sure you are connected to the internet when reinstalling so that AutoUpdate can properly update Office to the current version.
    4. Using Disk Utility to verify the startup disk and repair disk permissions.
    5. Reinstall Mac OS X
    If you have done ALL of these things and PowerPoint is still not working with the clipboard, then please contact Microsoft Support (see options near the bottom of this page). If your organization has Microsoft Support incidents, this would be a good time to use one.
    2014-05-13T18:00:49+00:00
    Richard,
    I did the repair disk permission, but the issue remains.
    Thank you
    2014-05-13T14:29:32+00:00
    Hi Gavin,
    Have you followed Jim Gordon's advice and contacted Microsoft Support? Look about 9 posts up from this one and you will see his posting.
    2014-05-13T11:20:52+00:00
    Hi All,
    I found this thread after finding the very same problem. I have V10.9.2 OS and MSOffice 2011 purchased over the net. Like others I am unable to copy and paste any shapes within Powerpoint by any method including the drop downs that are all greyed out. i have tried all suggested solutions on this thread to no avail including Rich's. This is extremely frustrating after just being a convert to Macs from Windows.
    Any further suggestions / help would be very welcome.
