Need help with conditional formatting using an IF function to recognise blank cells and overdue dates
2013-07-04T01:44:42+00:00
Hi
I am wanting to add conditional formatting to a spreadsheet which lists invoices and their due dates, along with payment date.
One column (H) has the payment due date.
Another column (M) has the date paid. This column is left blank if unpaid to date.
I want to highlight only cells in column H in which the due date is anything less than today, but ignoring those where there is a value in column M already. Essentially, I do not want to highlight anything which is overdue, but already paid (if that makes sense).
Having trouble working out what formula I need to do to show this in the conditional formatting area. I can get it to do the dates past easy enough, but cant get it to also ignore blank cells.
Have tried using ISBLANK.
Would greatly appreciate anyone's help with this formula!!
Thanks!!
Ashish Mathur 102.4K Reputation points Volunteer Moderator
2013-07-04T02:40:07+00:00
Try this
  1. Click on cell H2 and go to Home > Conditional formatting > New Rule > Use a formula to determine which cells to format
  2. In the formula bar there, enter this formula
=AND(H2<today(),I2="")
  1. Click on Format and select any Fill/Font colour
  2. Click on OK/Apply
  3. Copy cell H2, select H3:H50 right click > Paste Special > Formats
Hope this helps.
59 additional answers
    2014-04-09T04:12:10+00:00
    For some reason it does not show the Status Text, it will only highlight the colour of the status. Is there a way I can send you a copy of my excel register?
  2. Ashish Mathur 102.4K Reputation points Volunteer Moderator
    2014-04-09T02:23:58+00:00
    In cell B2, enter this formula and copy down
    =IF(C2<>"","Completed",IF(AND(TODAY()>A2,A2<>""),"Overdue",IF(A2<>"","On Target","")))
    2014-04-08T02:16:46+00:00
    It works somewhat. Is there a way for:
    • The word 'Overdue' to also come up when it turns RED i.e. that RED cell to say 'Overdue';
    • The word 'Completed' once completed/GREEN; and
    • The word 'On Target' as soon as a date is put in the 'Due' column.
    Also, Cell B2 is constantly RED. But I guess that is not a huge issue.
  4. Ashish Mathur 102.4K Reputation points Volunteer Moderator
    2014-04-08T02:03:17+00:00
    You are welcome.  Try this
    1. In cell B2, enter this formula in the Conditional formatting dialog box and format the cell as Green Fill colour
    =C2<>""
    1. In cell B2, enter this formula in the Conditional formatting dialog box and format the cell as Red Fill colour
    =AND(C2="",TODAY()>A2)
    Does this work?
