Need help with conditional formatting using an IF function to recognise blank cells and overdue dates
2013-07-04T01:44:42+00:00
Hi
I am wanting to add conditional formatting to a spreadsheet which lists invoices and their due dates, along with payment date.
One column (H) has the payment due date.
Another column (M) has the date paid. This column is left blank if unpaid to date.
I want to highlight only cells in column H in which the due date is anything less than today, but ignoring those where there is a value in column M already. Essentially, I do not want to highlight anything which is overdue, but already paid (if that makes sense).
Having trouble working out what formula I need to do to show this in the conditional formatting area. I can get it to do the dates past easy enough, but cant get it to also ignore blank cells.
Have tried using ISBLANK.
Would greatly appreciate anyone's help with this formula!!
Thanks!!
Ashish Mathur 102.4K Reputation points Volunteer Moderator
2013-07-04T02:40:07+00:00
Try this
  1. Click on cell H2 and go to Home > Conditional formatting > New Rule > Use a formula to determine which cells to format
  2. In the formula bar there, enter this formula
=AND(H2<today(),I2="")
  1. Click on Format and select any Fill/Font colour
  2. Click on OK/Apply
  3. Copy cell H2, select H3:H50 right click > Paste Special > Formats
Hope this helps.
59 additional answers
    2014-04-10T08:05:31+00:00
    But what about the formula you told me to put into I14 prior:
    =IF(J14<>"","Completed",IF(AND(TODAY()>H14,H14<>""),"Overdue",IF(H14<>"","On Target","")))
    This is what happens when I try these options.
    If I remove the above formula and apply =AND(H14<>"",TODAY()<H14,J14="") directly into cell I14 it comes up with 'FALSE'.
    If I create a new rule in cell B1 and apply it to I14, nothing changes.
  2. Ashish Mathur 102.4K Reputation points Volunteer Moderator
    2014-04-10T07:56:01+00:00
    Apply this to cell I14 and then copy the conditional formatting down.
    2014-04-10T07:48:14+00:00
    Which cell do I apply this to? Or do I apply it to a cell for Conditional Formatting?
  4. Ashish Mathur 102.4K Reputation points Volunteer Moderator
    2014-04-10T07:16:04+00:00
    Try this
    Hope this helps.
