Word for iPad won't activate
2014-03-29T03:20:57+00:00
I downloaded Word, Powerpoint and Excel for iPad yesterday and purchased a 365 Home Certificate. I tried to activate Word and am always given the message "Cannot Activate. This account doesn't have a paid Office 365 subscription." Then I tried activating Powerpoint and Excel -- knowing if you activate one, they're all activated -- and those won't activate either.
I have the receipt and Order ID from Apple and their phone support has been great, including today, Saturday. But ultimately, they can't help, because it's up to the developer (Microsoft). Everything is fine on the Apple side.
I have done everything possible, from rebooting, to reinstalling, to resetting my network connections, without success. So I tried to call Microsoft Support (through a link Apple kindly supplied) only to find they don't work on weekends.
I've searched the internet for solutions, but the program is so new that I appear to be the only one so far with a problem -- or maybe no one's buying a 365 Home subscription for the first time.
Any thoughts that don't include all the things I've already done would be appreciated.
Thank you,
Don
2014-07-08T14:32:22+00:00
Go to settings and look for the app there..  Do u see it?...  If so try doing a Word reset" and then reload or open from AppStore page..  Report back..
This worked for me on my iPad. These are the full steps I used:
  • Open up Settings
  • Scroll all the way to the bottom in the left hand pane, select Word
  • In the right hand pane, select Reset Word
  • Turn on Delete Login Credentials
  • IF you already have Word running on your iPad, as I did: Double-press the iPad's home button to bring up all currently running programs, swipe back and forth until you see Word, flick the Word screen up to stop the program
  • Press the iPad's home button to get back to the home screen
  • Select Word
  • Swipe all the way through the introductory screens until it says "Sign in now" - select Sign in
  • Enter your e-mail address, selected "Next"
  • Sign in to your Microsoft account with your e-mail and password, select "Sign in"
  • Select "Buy Office 365"
  • At the bottom, select the "Restore previous purchase" link
  • Enter your iTunes password
Yeesh.
211 additional answers
    2014-06-19T01:50:16+00:00
    So as of today, 18 June 2014, has this problem been resolved?
    2014-06-19T02:03:52+00:00
    Uhmm, yes, not still able to use it but ITunes is refuding my money for the subscription.... After the refund, will try to figure out how this will really work.. if it will... Thanks.
    2014-06-24T14:31:43+00:00
    Truemann,
    Sorry to hear about your experience.
    I see that when trying to buy form Excel, it did tell you that you already have the subscription (as expected). Did you get the same message when you tried to purchase from powerpoint?
    If you saw the same messge, Apple should not have charged you the last 2 times.
    Would you be alright with me getting in direct contact with you to resolve this issue?
    Sumesh
    (Microsoft Office Engg.)
    I have had the same issue of purchasing Office 365 twice since i had problems activating it. When i tried to request a refund from apple i got an auto reply stating that, "This purchase is not eligible for a refund".
    I feel ripped off and would be glad to get help on this.
    2014-06-25T18:35:40+00:00
    I tried the reset and still get the Can't Verify Subscription try again later.  I like the refund strategy. This is so ridiculous.
    Hi ductor,
    Sorry to hear that you are having issues. Here are a few steps you can try before doing a refund:
    1. Reset the app, which you say you have already tried. But below are the steps to make sure your are resetting everything about the app:
    Getting your app back to the First Run State:
    Go to Settings and then scroll down to the <Office app> you want to reset.
    Under RESET, tap Reset < Office app>.
    Turn on Delete Login Credentials.
    Close your app if it’s running before you start it again to see the first run screen and enter your new creds.
    To close, go to the Home screen of your iPad.
    Press the iPad's Home button twice rapidly. A list of your recent apps appears on the screen.
     Swipe up the app to close it.
    1. Reset your device (I understand this is a painful method).
    2. To get a refund, you will have to get in touch with Apple Customer Support and ask them to cancel your subscription and give you a refund.
    Let me know if either of the first 2 steps helped you resolve the issue.
    Sumesh
    I performed Step 1 from Sumesh's post above, but did not go on to reset my device. Instead, I went ahead and opened up the Word app, and when it asked me to purchase Office 365, I selected "Restore previously purchased version." I then entered my iTunes password, and was able to successfully open and use the full version of Word.
