Word for iPad won't activate
2014-03-29T03:20:57+00:00
I downloaded Word, Powerpoint and Excel for iPad yesterday and purchased a 365 Home Certificate. I tried to activate Word and am always given the message "Cannot Activate. This account doesn't have a paid Office 365 subscription." Then I tried activating Powerpoint and Excel -- knowing if you activate one, they're all activated -- and those won't activate either.
I have the receipt and Order ID from Apple and their phone support has been great, including today, Saturday. But ultimately, they can't help, because it's up to the developer (Microsoft). Everything is fine on the Apple side.
I have done everything possible, from rebooting, to reinstalling, to resetting my network connections, without success. So I tried to call Microsoft Support (through a link Apple kindly supplied) only to find they don't work on weekends.
I've searched the internet for solutions, but the program is so new that I appear to be the only one so far with a problem -- or maybe no one's buying a 365 Home subscription for the first time.
Any thoughts that don't include all the things I've already done would be appreciated.
Thank you,
Don
2014-07-08T14:32:22+00:00
Go to settings and look for the app there..  Do u see it?...  If so try doing a Word reset" and then reload or open from AppStore page..  Report back..
This worked for me on my iPad. These are the full steps I used:
  • Open up Settings
  • Scroll all the way to the bottom in the left hand pane, select Word
  • In the right hand pane, select Reset Word
  • Turn on Delete Login Credentials
  • IF you already have Word running on your iPad, as I did: Double-press the iPad's home button to bring up all currently running programs, swipe back and forth until you see Word, flick the Word screen up to stop the program
  • Press the iPad's home button to get back to the home screen
  • Select Word
  • Swipe all the way through the introductory screens until it says "Sign in now" - select Sign in
  • Enter your e-mail address, selected "Next"
  • Sign in to your Microsoft account with your e-mail and password, select "Sign in"
  • Select "Buy Office 365"
  • At the bottom, select the "Restore previous purchase" link
  • Enter your iTunes password
Yeesh.
211 additional answers
    2014-04-13T14:28:28+00:00
    Thanks Doug.
    I was not clear enough. On my iPad, I can see that Word, Excel and PowerPoint refer to my Microsoft Account. But when I access "My Account" in Microsoft website those apps are not there. My subscription is not available on "My Account" to be shared.
    Any support is much appreciated.
    Best
  2. Doug Robbins - MVP - Office Apps and Services 323.6K Reputation points MVP Volunteer Moderator
    2014-04-13T21:37:36+00:00
    Is Office there?  You will not see the individual Apps.
    2014-04-14T03:45:16+00:00
    Easy solution - but not quite as obvious as it should be.
    Open Word on you iPad.
    Click on "Buy Office 365 Home".
    A new box will up. Down at the bottom it should say, "I already have a subscription."
    Click on that.
    You will have to enter your iTunes password.
    Worked for me... I was about to raise bloody **** over a $99 subscription that didn't work.
    2014-04-14T03:57:30+00:00
    Easy solution - but not quite as obvious as it should be. Open Word on you iPad. Click on "Buy Office 365 Home". A new box will up. Down at the bottom it should say, "I already have a subscription." Click on that. You will have to enter your iTunes password. Worked for me... I was about to raise bloody **** over a $99 subscription that didn't work.
    It didn't work for most of us. If it had, this thread would be a lot shorter. ;-)
