Word for iPad won't activate
2014-03-29T03:20:57+00:00
I downloaded Word, Powerpoint and Excel for iPad yesterday and purchased a 365 Home Certificate. I tried to activate Word and am always given the message "Cannot Activate. This account doesn't have a paid Office 365 subscription." Then I tried activating Powerpoint and Excel -- knowing if you activate one, they're all activated -- and those won't activate either.
I have the receipt and Order ID from Apple and their phone support has been great, including today, Saturday. But ultimately, they can't help, because it's up to the developer (Microsoft). Everything is fine on the Apple side.
I have done everything possible, from rebooting, to reinstalling, to resetting my network connections, without success. So I tried to call Microsoft Support (through a link Apple kindly supplied) only to find they don't work on weekends.
I've searched the internet for solutions, but the program is so new that I appear to be the only one so far with a problem -- or maybe no one's buying a 365 Home subscription for the first time.
Any thoughts that don't include all the things I've already done would be appreciated.
Thank you,
Don
2014-07-08T14:32:22+00:00
Go to settings and look for the app there..  Do u see it?...  If so try doing a Word reset" and then reload or open from AppStore page..  Report back..
This worked for me on my iPad. These are the full steps I used:
  • Open up Settings
  • Scroll all the way to the bottom in the left hand pane, select Word
  • In the right hand pane, select Reset Word
  • Turn on Delete Login Credentials
  • IF you already have Word running on your iPad, as I did: Double-press the iPad's home button to bring up all currently running programs, swipe back and forth until you see Word, flick the Word screen up to stop the program
  • Press the iPad's home button to get back to the home screen
  • Select Word
  • Swipe all the way through the introductory screens until it says "Sign in now" - select Sign in
  • Enter your e-mail address, selected "Next"
  • Sign in to your Microsoft account with your e-mail and password, select "Sign in"
  • Select "Buy Office 365"
  • At the bottom, select the "Restore previous purchase" link
  • Enter your iTunes password
Yeesh.
211 additional answers
    2014-03-29T17:53:39+00:00
    Tony, I doubt the issue is with Apple settings.
    I think the problem is the purchase info is not being forward to microsoft, or microsoft is not processing it.
    I logged onto office 365 on my PC, they had my account (which I had verified by email) - but no record of my purchase of the subscription.
    Apple support says they are sending it to investigators and are processing a refund.
    I sent them the link to this thread.
    2014-03-29T17:57:42+00:00
    nowzen...
    the activation issue definitely not about settings...  i was responding to the previous query re the disappearing app !  ..
    2014-03-29T18:02:43+00:00
    nowzen...  your situation is exactly the same as mine..  i am still on with microsoft tech support and they have the entire senior team on it it seems with me on the phone..  i will post any fix that they come up with (its Jun in Manila who is leading the charge from their end..  not bad at 1 am !!)..
    2014-03-29T20:42:50+00:00
    Word is not in the settings.  When I scan down to check the iPad shuts down.   How can I just remove it
