Word for iPad won't activate
2014-03-29T03:20:57+00:00
I downloaded Word, Powerpoint and Excel for iPad yesterday and purchased a 365 Home Certificate. I tried to activate Word and am always given the message "Cannot Activate. This account doesn't have a paid Office 365 subscription." Then I tried activating Powerpoint and Excel -- knowing if you activate one, they're all activated -- and those won't activate either.
I have the receipt and Order ID from Apple and their phone support has been great, including today, Saturday. But ultimately, they can't help, because it's up to the developer (Microsoft). Everything is fine on the Apple side.
I have done everything possible, from rebooting, to reinstalling, to resetting my network connections, without success. So I tried to call Microsoft Support (through a link Apple kindly supplied) only to find they don't work on weekends.
I've searched the internet for solutions, but the program is so new that I appear to be the only one so far with a problem -- or maybe no one's buying a 365 Home subscription for the first time.
Any thoughts that don't include all the things I've already done would be appreciated.
Thank you,
Don
2014-07-08T14:32:22+00:00
Go to settings and look for the app there..  Do u see it?...  If so try doing a Word reset" and then reload or open from AppStore page..  Report back..
This worked for me on my iPad. These are the full steps I used:
  • Open up Settings
  • Scroll all the way to the bottom in the left hand pane, select Word
  • In the right hand pane, select Reset Word
  • Turn on Delete Login Credentials
  • IF you already have Word running on your iPad, as I did: Double-press the iPad's home button to bring up all currently running programs, swipe back and forth until you see Word, flick the Word screen up to stop the program
  • Press the iPad's home button to get back to the home screen
  • Select Word
  • Swipe all the way through the introductory screens until it says "Sign in now" - select Sign in
  • Enter your e-mail address, selected "Next"
  • Sign in to your Microsoft account with your e-mail and password, select "Sign in"
  • Select "Buy Office 365"
  • At the bottom, select the "Restore previous purchase" link
  • Enter your iTunes password
Yeesh.
211 additional answers
    2014-04-02T21:28:47+00:00
    I'm not sure what you mean by "rights for mobile devices." I've used my O 365 from a laptop and two different Chromebooks and had full access.
    2014-04-02T22:09:22+00:00
    There are different kinds of offers. Most likely if you have activated office on pc/macs, you should have rights to activate on mobile too.
    Can you double check if this is the case? Also you can send me your unique identifier (goto O365 settings and it should be under there) and I can verify this for you.
    -Sumesh
    2014-04-02T22:11:52+00:00
    Hi Mark,
    If your live account says you dont have a subscription, it would mean that the association of your apple purchase with your live id failed for some reason.
    Try logging in with your live account and then goto the "Buy" page again from within the app, only this time instead of buying hit "I already Have a subscription". This essentially tells apple that I have bought this previously and would like to try the association of subscription with my live id again. If this doesnt succeed in activating, let me know and I will work with you to fix it.
    Thanks for your patience,
    Sumesh
    (Microsoft Office Engg.)
    2014-04-02T22:26:07+00:00
    10033FFF844EFDC8
    That is my unique identifier. Thanks for your help.
