Change Product Key Office 2013 Home and Business
2013-03-07T14:44:07+00:00
Please check out Change<br> your Office license or product key for the latest information on this topic.
I need to change the product key on a new installation of Office 2013 Home and Business. What is the procedure?
2016-06-08T19:59:14+00:00
Hi everyone,
First off, on behalf of the Office team, thank you for posting your question in the Microsoft Office community and providing solutions. We have published an article that specifically addresses this question: Change your Office product key.
Hope you'll find this helpful.
Michelle V.
The Office Team
118 additional answers
    2013-05-15T20:08:03+00:00
    Reija, I feel your pain...
    Here is how to actually fix the issue, if you haven't already...
    Open up a Command Prompt (Start>CMD>Enter)
    Type in:
    If you 64bit Office with 64bit Operating System:
    cd "\Program Files\Microsoft Office\Office 15"
    Then
    cscript ocpp.vbs /dstatus
    Then
    Look at the Last 5 characters of the installed product key:
    Then
    cscript ospp.vbs /unpkey:(the last 5 characters of the product key above)
    Here's how to do it on a 32bit Office:
    cd "\Program Files (x86)\Microsoft Office\Office 15"
    Then
    Then
    Then
    Open up outlook, you should get a prompt to login to your Microsoft account.  Login and select the key that you are actually wanting to use.
  2. Deleted
  3. Deleted
    2013-05-21T19:34:51+00:00
    Type in:
    Then
    Then
    Then
    Then
    Then
    Then
    This seems to be the ticket, but ocpp.vbs does not seem to exist in /office15 32-bit. There is ospp.vbs, which I'm using for both.
    I think this works. Thank you. Note: I am not OP
