Change Product Key Office 2013 Home and Business
2013-03-07T14:44:07+00:00
Please check out Change<br> your Office license or product key for the latest information on this topic.
I need to change the product key on a new installation of Office 2013 Home and Business. What is the procedure?
2016-06-08T19:59:14+00:00
Hi everyone,
First off, on behalf of the Office team, thank you for posting your question in the Microsoft Office community and providing solutions. We have published an article that specifically addresses this question: Change your Office product key.
Hope you'll find this helpful.
Michelle V.
The Office Team
118 additional answers
  1. Deleted
    2013-05-05T02:16:17+00:00
    • Click on the button to open the Start Menu. Now, click on the Control Paneland then click on Programs (Uninstall a program), and finally click on Program and Features.
    (Windows XP users: Start > Control Panel > Add or Remove Programs.)
    • From the list of installed programs, find (or your installed version of Office 2010 or Office 2013) or Microsoft Office Visio Professional 2010 (or your installed version of Visio 2010), which ever’s key you want to change, select it and then click on Change.
    • From the newly opened dialog box, select the Enter a Product Key option, and then click Continue.
    • Type your new product key and check the option that says Attempt to automatically activate my product online to automatically activate your Office 2013 or Office 2010 suite. Now click on Continue and then on Install Now.
    The versions of Office 2013 I have used at work and at home didn't provide the option to Enter a Product Key after clicking on Change.  The versions I have at work didn't even provide a Change button (installed on Win 7 Pro).  They simply had the option to remove.  I'd attach a picture, but the only available options are Quick Repair and Online Repair for my 2013 Professional after clicking on Change (installed on Win 8 Pro).  The commands I listed above worked for me, though.
  3. Deleted
  4. Deleted
