Change Product Key Office 2013 Home and Business
2013-03-07T14:44:07+00:00
Please check out Change<br> your Office license or product key for the latest information on this topic.
I need to change the product key on a new installation of Office 2013 Home and Business. What is the procedure?
2016-06-08T19:59:14+00:00
Hi everyone,
First off, on behalf of the Office team, thank you for posting your question in the Microsoft Office community and providing solutions. We have published an article that specifically addresses this question: Change your Office product key.
Hope you'll find this helpful.
Michelle V.
The Office Team
118 additional answers
    2015-01-14T02:40:14+00:00
    There are no vbs files in  C:\Program Files (x86)\Microsoft Office\Office15
    2015-01-14T18:48:49+00:00
    It can be done via the command line.  Open up a Command Prompt (Press the Windows Button and type CMD or navigate to All Programs -> Accessories -> Command Prompt).  Then you just need to use the command below that matches your OS.
    For 32 bit Windows:
    cscript "C:\Program Files\Microsoft Office\Office15\OSPP.VBS" /inpkey:yourkeygoeshere
    For 64 bit Windows (assuming you are using 32 bit Office):
    cscript "C:\Program Files (x86)\Microsoft Office\Office15\OSPP.VBS" /inpkey:yourkeygoeshere
    Obviously, you need to replace yourkeygoeshere with your product key.
    Note:  If you are installing a 64 bit version of Office on 64 bit Windows, the command for 32 bit Windows should be used (or just delete the (x86) part since it won't be installing to the C:\Program Files (x86)\ directory).
    This worked perfectly - I entered the wrong key on my computer (it was for another system) and was getting the "key has already been activated the maximum number of times" -
    Once I realized this I could not figure out how to enter the correct key - after running the cscript command I'm in business!
    2015-01-19T19:00:27+00:00
    For 32 bit Windows:
    THank you.
    2015-01-21T02:35:59+00:00
    minta kode change product key
