Change Product Key Office 2013 Home and Business
2013-03-07T14:44:07+00:00
Please check out Change<br> your Office license or product key for the latest information on this topic.
I need to change the product key on a new installation of Office 2013 Home and Business. What is the procedure?
2016-06-08T19:59:14+00:00
Hi everyone,
First off, on behalf of the Office team, thank you for posting your question in the Microsoft Office community and providing solutions. We have published an article that specifically addresses this question: Change your Office product key.
Hope you'll find this helpful.
Michelle V.
The Office Team
118 additional answers
    2013-11-13T05:00:14+00:00
    the 64 bit systems do not have a ospp.vbs file
    the path for the office in the 64 bit folder is different as well
    "c:\Program Files\Microsoft Office15\
    a number of files are in the subfolders of this directory which begin with OSPP
    what is the correct ospp file to edit for the key change?
    I hit this issue as well, use the Program Files (x86) directory:
    cd "\Program Files (x86)\Microsoft Office\Office15"
    Then you can run the cscript ospp.vbs options as follows:
    C:\Program Files (x86)\Microsoft Office\Office15>cscript ospp.vbs /dstatus
    Microsoft (R) Windows Script Host Version 5.8
    Copyright (C) Microsoft Corporation. All rights reserved.
    ---Processing--------------------------
    SKU ID: cd256150-a898-441f-aac0-9f8f33390e45
    LICENSE NAME: Office 15, OfficeHomeBusinessR_Retail edition
    LICENSE DESCRIPTION: Office 15, RETAIL channel
    BETA EXPIRATION: 1/01/1601
    LICENSE STATUS:  ---OOB_GRACE---
    ERROR CODE: 0x4004F00C
    ERROR DESCRIPTION: The Software Licensing Service reported that the application
    is running within the valid grace period.
    REMAINING GRACE: 27 days  (38881 minute(s) before expiring)
    Last 5 characters of installed product key: XXXXX
    ---Exiting-----------------------------
    Then update the Key (note I have put XXXX in instead of showing my actual key):
    C:\Program Files (x86)\Microsoft Office\Office15>cscript ospp.vbs /inpkey:XXXXX-
    XXXXX-XXXXX-XXXXX-XXXXX
    <Product key installation successful>
    Hope that helps.  I had to do this after I cloned a fresh system before activating Office.  Didn't have some of the "change key" options others have mentioned.
    This was actually quite helpful and almost got me there but the "software licensing service reported that the action requires administrative privilege"  It is a home PC and I am the administrator.  Bummer, I thought I was there.  I am going to just uninstall and reinstall.  It is just too much and it is easier at this point...
    2013-11-14T15:58:47+00:00
    To find the product key in a Microsoft account try this:
    1. Look at Account Options (under install)
    2. Choose Install from a disc
    3. Choose I want to burn a disc
    4. Click on View your product key button
    2013-11-21T06:33:40+00:00
    I find an article talking about Office 2013 product key, you can read it as below and I hope it helpful:
    http://www.recoverlostpassword.com/article/office-2013-product-key.html
  4. Deleted
