Outlook 2013: Inbox does not refresh after deleting an email
2013-02-04T17:13:44+00:00
When I delete an email (or multiple emails) from my inbox, the inbox view does not refresh; the deleted emails are still there. I must move the inbox scroll bar to force a refresh. Even then, it leaves me at the start of the inbox, rather than at the current email.
Does anyone else have this problem? Does anyone have a solution? Or, is it a bug?
I have the inbox set to oldest on top/newest on the bottom.
Office 365 Home/Premium
Windows 7, SP1, 64-bit, all patches installed
16 MB
Core i7-2600K, 3.4 GHz
Plenty of free disk space
Stan
    2014-04-18T20:50:29+00:00
    After 8 hours and three levels of MS support later...
    Per the Outlook Escalation Team: "I just wanted to update you that this is a known problem, and one for which  a hot fix request has already been filed with the product group. From what I gather..it will be a couple of months before the fix is available as a public download."
    2014-05-09T21:31:50+00:00
    I now understand how to replicate this problem...
    it only happen when reading an email in full screen and delete it.
    If email is in a non maximized window it deletes, and refresh inbox just fine...
    I have confirmed this as true.  I like to have my e-mail full screen and when I delete from an opened e-mail, it causes this refresh issue.  If I open a read e-mail windows, it deletes and refreshes normally.
    Thank you for finding the specific instance on how to recreate this error.  Hopefully Microsoft engineers will be able to resolve.
    I did update my Office 365 to version 15.0.4605.1003 which did not resolve the issue.
    2014-05-10T13:41:28+00:00
    Thanks for this clarification.
    2014-05-21T19:38:43+00:00
    Same problem here.  Did you get a case number or something we can check with MSFT on to see the progress on this one?
    To be clear - no issue with the delete key.  but when using the X-Delete button in the ribbon the screen does not refresh.  The message is deleted but still shows up in the listing.  Disabling the add-ins did not help.
    2014-06-04T08:47:22+00:00
    Today I got a new laptop.
    After installing outlook 2013 this issue is not happening.
    The only difference I can see at first was the themes, on my old installation I had windows themes disabled (even the service) and in this new windows 7 installation is still in the default theme.
    The resolution and video card is also different.
