Processes in Microsoft 365 for setting up Office apps, redeeming product keys, and activating licenses.
right click> run as admin and activate
I just purchased a one month subscription for Office 365 Home Premium for 5 PCs and installed on my PC (Alienware M17XR4 Windows 7). Now whenever I try to activate my Office it fails and the error shown is - "We're sorry, something went wrong and we can't do this for you right now. Please try again later. ( 0x80070005 )".
I still have about 25 days' subscription left.
Please tell how I can activate this.
This worked for me
"In case you haven't already found the solution right click on Excel 2013 (or any other Office 2013 application) and select 'Run as Administrator' then follow the steps to activate online"
Hello Dennis,
You may uncheck the option running in compatibility mode if checked and check the option ‘Run the file as administrator’:
Check if Excel is running in compatibility mode by following the step below:
· Close Excel.
· Browse to the location mentioned below:
For Win8 32 bit:
· C:, Program Files, Microsoft Office, Office15
For Win8 64 bit:
C:, Program Files (x86), Microsoft Office, Office15
· Right click on Excel.exe, Properties, Compatibility
· Uncheck the box Run this Program in Compatibility Mode, Make sure you also click on the option change settings for all users tab at the bottom of the same screen and check the option Run this program as an administrator. Click **** on Apply and Ok.
I hope the above information helps. Let us know if you need further assistance.
Thank you.
Had several different computers do this.
Right-clicking on Excel (or other Office program; in the Start Menu) and selecting Run as administrator allowed it to activate for some.
For those that didn't, this thread got it working:
Open command prompt as administrator.
cd \Program Files (x86)\Microsoft Office\Office15
enter cscript ospp.vbs /act
BTW, the 0x8007005 error is "Access is denied" (from running the command cscript ospp.vbs /ddescr:0x80070005)
Thanks Peter,
I tried this but had the same old "something went wrong" message. Have spent two days trying to get this sorted out, so far.
Norma
