Comment balloons will not print. WORD 2010
2011-10-25T22:05:21+00:00
Comment balloons will not print.  I have a document that has insertions and deletiions in the text and comments in balloons in the right margin.  When I try to print it, the space is there in the right hand marginto accomidate the ballons but the balloons don't print.  They show up in the Word Print Preview.
2014-01-15T14:08:17+00:00
This is a very old thread, but i'll post here as it's the top Google answer for 'word comments not printing.' I had this problem with a couple of users and i found the problem was that if a document is displayed in the Windows Explorer preview pane comments balloons won't print. With the preview pane disabled (or if you open the document from within Word, as others suggested), it will work.
If it has been opened in the preview pane you need to open task manager and kill winword.exe if it is running in order for it to work.
2012-05-17T17:55:05+00:00
Here's what works for me.  It is still annoying, but at least I can get the comments to print in the shaded area on the paper to match the print preview.  This works for me for printing to PDF, to a networked HP, and to a networked Xerox Mobile Express driver.  I hope it works for you, too.
  1. Close Word.
  2. Re-open Word.
  3. Using Word (not Windows Explorer), open the document.
  4. Print your file.  On the Print page, under Settings, click the button that holds the options like "Print all pages" and make sure that the "Print mark-up" is checked.
I've started doing a test run by printing 1 page to the printer "Adobe PDF", so I know the comment balloons are really printing. This keeps me from wasting paper and pricey color toner, and saves the interruption of a jog down the hall to the network printer.  Once I know the balloons are visible in the PDF, then I send the whole document to print on the network printer.
119 additional answers
  1. Stefan Blom 351.7K Reputation points MVP Volunteer Moderator
    2013-07-15T21:52:44+00:00
    I tried this and it still did not work for me. My document is still printing but no comments or tracked changes are showing in the boxes on the right when I print.
    What do you see in Print Preview (Ctrl+F2)? Which version of Word are you using?
    2013-07-15T21:41:05+00:00
    2013-07-08T09:29:39+00:00
    This does not work for me, alas.
    I have the identical problem of the original poster, i.e. while the comment bubble margin prints, and the bubbles show in print preview, the bubbles do not print; instead, the comment number appears inline.
    I've had this problem in Word 1997-2003, 2007, and now 2010; and it has wasted enormous amounts of my time.
    It happens both at work and home, and to others; moreover, it happens when I print to pdf (i.e. the comment margin but not the bubbles print).  So it is NOT a printer problem.
    It does NOT happen all the time.   All sorts of things sometimes *seem* to help (e.g. opening the document in Word; pasting the text into a new document; turning the computer and printer on and off again) but nothing *reliably* solves it, e.g. I have a document open right now, whose comments won't print, and I've tried all those methods without success.
    PLEASE can someone suggest something, or could MS get on a fix what is surely a bug.
    David
