Comment balloons will not print. WORD 2010
2011-10-25T22:05:21+00:00
Comment balloons will not print.  I have a document that has insertions and deletiions in the text and comments in balloons in the right margin.  When I try to print it, the space is there in the right hand marginto accomidate the ballons but the balloons don't print.  They show up in the Word Print Preview.
2014-01-15T14:08:17+00:00
This is a very old thread, but i'll post here as it's the top Google answer for 'word comments not printing.' I had this problem with a couple of users and i found the problem was that if a document is displayed in the Windows Explorer preview pane comments balloons won't print. With the preview pane disabled (or if you open the document from within Word, as others suggested), it will work.
If it has been opened in the preview pane you need to open task manager and kill winword.exe if it is running in order for it to work.
2012-05-17T17:55:05+00:00
Here's what works for me.  It is still annoying, but at least I can get the comments to print in the shaded area on the paper to match the print preview.  This works for me for printing to PDF, to a networked HP, and to a networked Xerox Mobile Express driver.  I hope it works for you, too.
  1. Close Word.
  2. Re-open Word.
  3. Using Word (not Windows Explorer), open the document.
  4. Print your file.  On the Print page, under Settings, click the button that holds the options like "Print all pages" and make sure that the "Print mark-up" is checked.
I've started doing a test run by printing 1 page to the printer "Adobe PDF", so I know the comment balloons are really printing. This keeps me from wasting paper and pricey color toner, and saves the interruption of a jog down the hall to the network printer.  Once I know the balloons are visible in the PDF, then I send the whole document to print on the network printer.
119 additional answers
    2015-02-03T00:24:16+00:00
    I have not experienced it with another document and successfully printed this document with changes and balloons at an earlier stage.  Everything is set up properly as set out in the referenced material.  There is even a large blank right hand margin to accommodate the comments and i see them in print preview but they don't print.
     Did YOU ever get a solution to this problem?  If so please share...I was able to print a REVIEW document last week with comments in the margain in their balloons.
    This week, no matter what I do, I cannot get the comments to print.
    2015-01-05T01:49:48+00:00
    I just encountered this problem, and none of the solutions here worked for me.
    Here's what did work for me: I saved a copy of the document in Word 2003-07 compatibility mode, then printed that copy. For whatever reason, the balloon text printed properly this way.
    This is the opposite of what T. Frost did, so maybe saving in a different format--either from .doc to .docx or .docx to .doc--somehow fixes the problem.
    For me, I had to save a current DOCX document as a DOC document.
    Then, reopen FROM WITHIN WORD.
    This worked for me.
    Do all the other things, like be sure Print Markup is set under the PRINT SETTINGS (all, current page, etc, look down at bottom of this list).
    2014-12-15T16:23:30+00:00
    As you are able to see the data correctly in print preview it may be the issue with the printer did you try to change the default printer as mentioned in the previous post, if no, change the default printer as mentioned in the previous post and verify the status.
      Changing the default printer worked for me.
