MS Office desktop icons move after I modify and save them.
2010-02-25T23:36:10+00:00
My MS word and excel documents that I have on the upper right hand area of my desktop move after I modify and save them.  If I open them and don't save them nothing happens, but if I modify and save them, they move to the far left aligned with other icons.  They do not appear to be temp or hidden files.  They just move to the far left arranged with other icons.  I want to modify and save them and the files to stay in the upper right hand area...  Help???
2010-02-26T17:12:02+00:00
Turn off the “Auto Arrange” option for icons on the desktop, and then place icons on the desktop where you want them.
To turnoff the “Auto Arrange” feature,
For windows 7:
Right click a blank area on the desktop and select View and uncheck Auto arrange icons.
For Windows XP:
Right-click a blank area on the desktop, and then click Arrange Icons. Click the command that indicates how you want to arrange the icons (by Name, by Type, and so on), uncheck Auto Arrange.
Niranjan I K Microsoft Answers Support Engineer.
• We appreciate your participation in MS Forums, Help us understand your needs better. To share your valuable Feedback please Click here.
44 additional answers
    2016-01-24T02:50:39+00:00
    They still move sporaticly after start ups
    2016-01-24T02:52:44+00:00
    With a unoriginal I too tried that and it did not work for me
    2016-08-18T10:00:25+00:00
    Tried this -
    To keep  W8 and Office 10 from shifting your icons around when you re-save, try the following:
    Open Word and select a blank document.
    Click on File > Options > Advanced
    Scroll way down to Save and
    Deselect  "Allow background saves".
    and YES - it works, fixed the jumping around problem
    2016-09-05T15:08:31+00:00
    I can't arrange Any icon At All! Help!
