internet links not working in Outlook 2010. "General Failure. The URL Was: http://frustration.com, etc. Application not Found"
2010-08-24T17:52:32+00:00
I've tried all the solutions I've been able to find re 2007, etc.  None has worked.  I reset explorer to default internet browser, re-linked all file associatinos such as HTML, SHTML, etc. to internet explorer.  Nothing works.  This really is frustrating.  All the great features of Outlook 2010 are more or less off set by this bug.  Has anyone found a way to fix this?  Thank you.
2010-08-25T09:48:54+00:00
Try the steps below and check if it resolves the issue.
Disclaimer: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk
Visit the link below for more information on registry back-up:
http://windows.microsoft.com/en-us/windows7/Back-up-the-registry
Click ‘Start’ and type ‘Run’ in the ‘Search programs and files’ box above ‘Start’ and hit ‘Enter’. In the Run window type ‘regedit’ (without quotes) and click ‘Ok’. Now navigate to the following location:
HKEY_CLASSES_ROOT\FirefoxURL\shell\open\ddeexec
At the right pane double click ‘(Default)’ and clear the ‘Value data:’ field and click ‘Ok’.
2012-01-05T15:23:10+00:00
I have had a problem for a long time where outlook was unable to open hyperlinks -- it would always ask you for what to open it with polluting the registry with a number of strange extensions (from the end of the url).  I dealt with it until a link had .exe on the end (it was an internal download link) which then caused windows to forget what to do with .exe files.
Citrix had a similar issue and had the magic register key set after resetting the browser associations,...
Copy this to a .reg file and import it to complete the association.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\htmlfile\shell\open\command]
@=""C:\Program Files\Internet Explorer\iexplore.exe" -nohome"
[HKEY_CLASSES_ROOT\htmlfile\shell\opennew\command]
@=""C:\Program Files\Internet Explorer\iexplore.exe" %1"
[HKEY_CLASSES_ROOT\http\shell\open\command]
[HKEY_CLASSES_ROOT\https\shell\open\command]
[HKEY_CLASSES_ROOT\IE.HTTP\shell\open\command]
[HKEY_CLASSES_ROOT\IE.HTTPS\shell\open\command]
[HKEY_CLASSES_ROOT\mms\shell\open\command]
"MPlayer2.BAK"=""C:\Program Files\Internet Explorer\iexplore.exe" -nohome"
[HKEY_CLASSES_ROOT\pnm\shell\open\command]
[HKEY_CLASSES_ROOT\rtsp\shell\open\command]
[HKEY_CLASSES_ROOT\rtspu\shell\open\command]
73 additional answers
    2014-11-11T16:18:47+00:00
    I changed the default browser settings. Internet explorer had only 6 of 14 defaults set to it, Firefox had the rest. I changed it so that all the defaults are now Internet Explorer and I no longer get this error. You can change the default settings in by going to the control panel, then searching for default programs, and then set default programs.
    2016-01-26T20:39:50+00:00
    This happened to me today as well and I read through all these "Answers." Then I reflected on what the cause might be. Just earlier I wanted to switch my default browser from Firefox to Chrome. In doing so what happened was that Chrome glommed all the HTML and protocol automation servers, including those that should belong to Outlook 2010. At that point Outlook would no longer open links, not did Chrome open (due to the automation execution failure).
    Firstly, I tried to turn off the Checks in Chrome for the automation features it shouldn't open. Turns out, Chrome wouldn't let me uncheck them. Still don't know why. So, I closed all browsers and Outlook, re-opened Firefox and set it again as the default browser. Then I went back to Control Panel\Programs\Default Programs\Set Default Programs and checked Outlook's settings. They were now correct again.
    I opened Outlook again and the links worked.
    Chrome may be part of the problem here though I may have inadvertently checked the ALL checkbox on automation servers. In any event, this process worked. Hope it works for others.
    2016-03-02T16:01:20+00:00
    In dwz post on Jan 5, 2012 listed a registry script with the paths of the "..shell\open\command" keys where it stores information about which browser and how to start that browser when you click on a URL.  For some reason when I switch to Internet Explorer as my default browser it puts in those "DelegateExecute" strings with GUID value "17FE9752-0B5A-4665-84CD-569794602F5C" under those registry keys, but there is no COM library or executable registred under that GUID causing the class not registered error.  It looks like when the "DelegateExecute" string exists it will try and start the browser using a delegate COM library or executable instead of using a shell command.  So I believe when I removed those "DelegateExecute" strings using regedit.exe it stopped trying to use the delegate and instead use the shell command to start Internet Explorer.
    the class not registered error, because this CLSID {17FE9752-0B5A-4665-84CD-569794602F5C} not exist in windows registry.
    you need to export this key from other windows 7 and import to your pc
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID{17FE9752-0B5A-4665-84CD-569794602F5C}]
    this GUID belong to C:\Program Files\Internet Explorer\ieproxy.dll
    you can compare this registry key with other pc that have no problem.
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID{17FE9752-0B5A-4665-84CD-569794602F5C}\InProcServer32]
    @=hex(2):43,00,3a,00,5c,00,50,00,72,00,6f,00,67,00,72,00,61,00,6d,00,20,00,46,\
      00,69,00,6c,00,65,00,73,00,5c,00,49,00,6e,00,74,00,65,00,72,00,6e,00,65,00,\
      74,00,20,00,45,00,78,00,70,00,6c,00,6f,00,72,00,65,00,72,00,5c,00,69,00,65,\
      00,70,00,72,00,6f,00,78,00,79,00,2e,00,64,00,6c,00,6c,00,00,00
    "ThreadingModel"="Apartment"
    or try register the IEProxy.dll
    regsvr32 IEProxy.dll
    https://support.microsoft.com/en-us/kb/928427
