MS Office 2010 PROBLEMS!!
2010-06-10T02:35:48+00:00
When I start any of the MS Office 2010 problems it gives me the following errors - "Please wait while Windows Configures Microsoft Office - gathering required information."  Does anyone have any idea what is going on or what I am suppose to do to fix this problem?  I have tried re-installing and running the Fix Software application that was included in the software.   The version of MS Office that I have is NOT the beta version, I just purchased it from online.  Please assist - thanks!!
Ken
2010-06-20T09:55:27+00:00
Open Run (Press Windows key + R) copy and paste the following commands one at a time and then press ENTER. You may receive a prompt to click on the continue/allow button.
Disclaimer: Modifying REGISTRY settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of REGISTRY settings can be solved. Modifications of these settings are at your own risk.
Ensure to back-up the registry using the steps givenhere before modification.
reg add HKCU\Software\Microsoft\Office\14.0\Word\Options /v NoReReg /t REG_DWORD /d 1
reg add HKCU\Software\Microsoft\Office\14.0\Excel\Options /v NoReReg /t REG_DWORD /d 1
reg add HKCU\Software\Microsoft\Office\14.0\Access\Options /v NoReReg /t REG_DWORD /d 1
Once the registry keys are added, try to open the target Office applications and verify if it fixes the issue.
2010-06-20T19:05:41+00:00
Thanks Niranjan!
I solved the problem after my rather rude (though understandably frustrated) post yesterday.
It turns out that simply turning off the Anti-Virus program before the install may not be enough. I discovered this after I installed the program on a second computer in my home. The computer I was having problems with had ZoneAlarm Extreme Security and the other computer had BitDefender Antivirus. Although I had turned off the real time virus scanning of both AVP's the ZoneAlarm program still had other protection services running in the background which were preventing access to certain keys (HKLM\Classes) in the registry.
I uninstalled ZoneAlarm and then was able to install Office 2010 without any problems and it was running correctly without any more annoying "Wait while Windows..." messages. I then re-installed ZoneAlarm and everything still works fine.
It may not be necessary to uninstall an AVP if one knows what services it may be running in the background and turns them off in the Services Contol Panel but removing and reinstalling an Anti Virus Program is certainly far easier and quicker than formatting a hard drive and reinstalling everything.
If people are receiving this message it is most likely due to their Anti-Virus/Anti-Malware program interfering with the install.
Michael
41 additional answers
    2010-12-03T16:44:11+00:00
    Sweet!
    Rodney
    2010-12-23T14:26:30+00:00
    I've done all the stuff suggested here to no avail, but FINALLY found a solution.... this problem seems so wide spread with many "solutions" that don't work, here's what worked for me.
    After another month of work on this, my problem HAS been solved. It wasn't Office specifically, but had to do with Registry permissions. As I understand it when an office app opens it checks the registry for stuff and if it can't access certain items (because of permissions) it assumes an install is needed. As I read more on this it started to make sense. Microsoft makes a tool to fix registry permissions and after following these instructions all my problems were solved. Not even a reboot necessary. All apps open immediately now.
    Here's the link with the information:
    http://blogs.msdn.com/b/astebner/archive/2006/09/04/739820.aspx
    I had to alter one thing from the text you copy -- it says %programfiles% and since I have a 64 bit Vista, I had to change that beginning line to %programfiles(x86)%
    As he says in the instructions, you replace YOURUSERNAME and suggests quotes if you have a space like this "John Doe" -- I did this also.
    It took around 5 minutes or so for this to run but IT WORKED!!!!!
    2010-12-27T16:27:53+00:00
    I spent way too much time on this problem as most of the other posters here have also done. Finally, I did what Tromba 2 suggested and followed the instructions provided by the link:
    It fixed my problem. In case you were wondering.... my problem was that every time I tried to open a PPS attachment in an email, I would get the "please wait while windows configures Microsoft office single image 2010" installer.
    This is not the first time a registry protection problem has caused me problems. The previous time a MSDN support called was used to fix that problem. That was a installation problem as well.
