MS Office 2010 PROBLEMS!!
2010-06-10T02:35:48+00:00
When I start any of the MS Office 2010 problems it gives me the following errors - "Please wait while Windows Configures Microsoft Office - gathering required information."  Does anyone have any idea what is going on or what I am suppose to do to fix this problem?  I have tried re-installing and running the Fix Software application that was included in the software.   The version of MS Office that I have is NOT the beta version, I just purchased it from online.  Please assist - thanks!!
Ken
2010-06-20T09:55:27+00:00
Open Run (Press Windows key + R) copy and paste the following commands one at a time and then press ENTER. You may receive a prompt to click on the continue/allow button.
Disclaimer: Modifying REGISTRY settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of REGISTRY settings can be solved. Modifications of these settings are at your own risk.
Ensure to back-up the registry using the steps givenhere before modification.
reg add HKCU\Software\Microsoft\Office\14.0\Word\Options /v NoReReg /t REG_DWORD /d 1
reg add HKCU\Software\Microsoft\Office\14.0\Excel\Options /v NoReReg /t REG_DWORD /d 1
reg add HKCU\Software\Microsoft\Office\14.0\Access\Options /v NoReReg /t REG_DWORD /d 1
Once the registry keys are added, try to open the target Office applications and verify if it fixes the issue.
2010-06-20T19:05:41+00:00
Thanks Niranjan!
I solved the problem after my rather rude (though understandably frustrated) post yesterday.
It turns out that simply turning off the Anti-Virus program before the install may not be enough. I discovered this after I installed the program on a second computer in my home. The computer I was having problems with had ZoneAlarm Extreme Security and the other computer had BitDefender Antivirus. Although I had turned off the real time virus scanning of both AVP's the ZoneAlarm program still had other protection services running in the background which were preventing access to certain keys (HKLM\Classes) in the registry.
I uninstalled ZoneAlarm and then was able to install Office 2010 without any problems and it was running correctly without any more annoying "Wait while Windows..." messages. I then re-installed ZoneAlarm and everything still works fine.
It may not be necessary to uninstall an AVP if one knows what services it may be running in the background and turns them off in the Services Contol Panel but removing and reinstalling an Anti Virus Program is certainly far easier and quicker than formatting a hard drive and reinstalling everything.
If people are receiving this message it is most likely due to their Anti-Virus/Anti-Malware program interfering with the install.
Michael
41 additional answers
    2010-11-07T21:27:04+00:00
    Well I am in the same boat, needs some serious help.
    I have added all three registry entries and am still getting the "blah installing " message when running from menu, when i trump down explorer to the .exe files excel still fires up a fresh configuration menu that takes about 3 mins.  Frustrating or what.  I'm not keen to uninstall as others have had other problems.
    2010-11-12T13:32:58+00:00
    Refer to the article KB 928218 to uninstall Office 2010 manually from the computer which would remove office completely. Later, restart the computer, reinstall Office 2010 and verify the status of the issue.
    Note: Look for registry keys containing ’14.0’ instead of ’12.0’ as mentioned in the article KB 928218 to uninstall Office 2010.
    2010-11-15T01:11:42+00:00
    Turned off everything.... all services (except Microsoft) and all startup programs. Didn't make any difference. Still have configurations all the time.
