Receiving an error that my product key is invalid
2010-01-18T17:07:08+00:00
My Office program is asking me to enter my product key, and when I do, it keeps giving a message saying that my product key is invalid.  I don’t know what else to do, I’m sure I’m entering the right numbers and letters.
2010-01-18T17:14:38+00:00
Hi Sangeetha
This is a very common question, and the answer is usually one of these two scenarios:
1.       Did you just install Office from a retail box you just purchased?  If so, go to Control Panel, Programs, Programs and Features and see if there is another copy of Office installed besides the suite you just installed.  Some pre-installed Trial Office 2007 suites can conflict with the product key validation process.  If you see a duplicate copy of Office installed, then uninstall it and try to run your new Office program again.  Chances are your product key will work now.
2.       If you are using the 25-digit product key that you found on a sticker on the bottom of your laptop or on the back of your desktop case, then you are using the wrong key.  This key is the product key for the Windows operating system, and NOT for the Office Suite.  The correct product key for the Office suite will be in one of these places:
a.       Inside the retail Office 2007 box (if you bought Office from a retail store)
b.      Inside an e-mail from the online website where you purchased Office
c.       On the outside of the CD case, on a sticker
Microsoft has a knowledge base article that goes into more detail around the invalid product key scenario.  It is located at
http://support.microsoft.com/kb/836178  , and would be a good place to go if these instructions above do not resolve your issue.
82 additional answers
    2016-02-22T19:41:47+00:00
    i have an office 365 product key but keep on getting
    Hang on to your product key, and try again later.
    If this happens again, contact support.
    Error code: ERR_MISSING_PARTNUMBER
    Correlation ID: 26de291f-3ca8-4e36-84c0-4f9a1865fa71
    help
    2016-03-15T00:36:58+00:00
    every time i entered product key.tells me my windows 7 is not Genuine.. need help bad. need to upgrade to windows 10. causing lots of problems....9803370737,call if nessasery...............HELP
    2016-04-27T04:08:02+00:00
    I've followed every step.  Apparently I have an account and also a reserved account I cannot access and when trying to finalise it in step 3 it tells me it cannot do it as it was set up with another email address that is not ours?? Com on does it have to be this hard to try and do something basic on my computer.  its really starting to **** me off as I cannot get any work done.  Want answers straight away!!!
    2016-08-10T01:19:42+00:00
    This computer does not seem to have a windows word so I'm not sure what
    you mean... where do I go now?
