Receiving an error that my product key is invalid
2010-01-18T17:07:08+00:00
My Office program is asking me to enter my product key, and when I do, it keeps giving a message saying that my product key is invalid.  I don’t know what else to do, I’m sure I’m entering the right numbers and letters.
2010-01-18T17:14:38+00:00
Hi Sangeetha
This is a very common question, and the answer is usually one of these two scenarios:
1.       Did you just install Office from a retail box you just purchased?  If so, go to Control Panel, Programs, Programs and Features and see if there is another copy of Office installed besides the suite you just installed.  Some pre-installed Trial Office 2007 suites can conflict with the product key validation process.  If you see a duplicate copy of Office installed, then uninstall it and try to run your new Office program again.  Chances are your product key will work now.
2.       If you are using the 25-digit product key that you found on a sticker on the bottom of your laptop or on the back of your desktop case, then you are using the wrong key.  This key is the product key for the Windows operating system, and NOT for the Office Suite.  The correct product key for the Office suite will be in one of these places:
a.       Inside the retail Office 2007 box (if you bought Office from a retail store)
b.      Inside an e-mail from the online website where you purchased Office
c.       On the outside of the CD case, on a sticker
Microsoft has a knowledge base article that goes into more detail around the invalid product key scenario.  It is located at
http://support.microsoft.com/kb/836178  , and would be a good place to go if these instructions above do not resolve your issue.
82 additional answers
    2010-10-21T02:35:41+00:00
    next time don't get microsoft products - they are not supported and dont load
    I've tried everything to install office 2010 - it wont even give an error message
  2. Deleted
    2010-10-29T01:18:06+00:00
    i'm having the problem with the trial version for Office 2010 Home and Business.
    I had it installed and my period expired, so I've completely uninstalled it, using the MS FIX IT removing tool, glary utilities and ccleaner to clean up all the registry and stuff...
    then i went to MS website to get a new trial key, got it in my email, copied and pasted it... the program says "the key is valid" then, once i click the next button i get the message - Failure installing product key. Please try another key.
    I'm sorry if the translation isn't accurate at all terms as my OS and software are in brazilian portuguese.
    2010-11-03T05:52:02+00:00
    I am having the smae problem. The only other problem I have is you said if we are using the 25-digit product key found on the sticker on the bottom of the laptop that it's the wrong key...
    That is the only product key I have. My laptop was a gift and I was told that everything was all set up but I can not get my word to work properly. Please advise...
    Thanks so much!
    Amanda
