A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
Interesting. I would happliy delete all the updates if I knew which ones were not "security" updates - and if new it was not a security update causing the problem.
I purchased a laptop in January and used Word 2010 with no issues. A few months later, I get hit with this problem. At one point I send my laptop in for service , and the company wipes the hard drive. The problem disappears!
Following the installation of updates, for security and whatever else Microsoft updates, for, the problem comes back.
If I perform a system restore to get rid of all the updates, the problem goes away. My conclusion: at least for my system, it's one of Microsoft's updates that cause the problem. I don't have the time to set a new system restore point for each update, install the update and use Word to see if that particular one is causing the problem, but if anyone else (like MICROSOFT for example) would like to figure out which update it is, I will happily remove it.
In the meanwhile, I have downgraded to Word 2007 and am using Adobe fonts without issue.
