Word 2010 Font Problem: different fonts showing up on screen
2010-06-09T21:52:26+00:00
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
2010-06-24T19:57:39+00:00
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
2010-06-28T15:17:36+00:00
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
2010-06-16T09:05:01+00:00
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
161 additional answers
    2011-07-21T21:31:51+00:00
    Adding the Hindi language as suggested by electroscribe and others has stablized it immensely for me. I have only been trying this out for an hour or so but so far so good.
    After another hour, I have had some problems using my Futura fonts but I was able to mess around and get my job done. Microsoft really needs to fix this.
    2011-07-08T16:46:36+00:00
    I have tried almost everything, including weeks of back and forth with Microsoft Support; their tech tells me it's not a Microsoft problem, it's Linotype, or it's Adobe, or it's NVIDIA, or it's Lenovo, and so on. I installed the click to run, then 32-bit, then 64-bit versions of Word: no solution. I upgraded my graphics driver: no solution. I reinstalled a clean version of Windows 7 on my laptop: no solution. I sent in my laptop to have the video card replaced (an NVIDIA NVS 3100m) and the hard drive wiped to its initial state, and the problem was fixed... for about two months. Upon installing an update, possibly Service Pack 1 for Office, but I can't be sure, the problem came back, and I'm ready to throw my computer into a hole and bury it.
    I don't think I can go through another two month long support session... I will either downgrade to Word 2007, or consider migrating over to OpenOffice if possible, if Microsoft doesn't get this stupid problem fixed.
    Incidentally, I uninstalled Service Pack 1 and then selected the Word 2007 layout option under the advanced options tab. My non-system font still displays in Arial; however, the spacing is fine and the pages don't overflow. The problem isn't fixed but I can (barely) function with these settings.
