Word 2010 Font Problem: different fonts showing up on screen
2010-06-09T21:52:26+00:00
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
2010-06-24T19:57:39+00:00
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
2010-06-28T15:17:36+00:00
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
2010-06-16T09:05:01+00:00
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
161 additional answers
    2011-06-20T16:34:03+00:00
    Until now I've had the same problem - Windows 7, Office Pro 2010, a bunch of Adobe CS3 and CS5 things installed, Garamond fonts reverting to arial, compressing into inkblots or spreading out over multiple lines, generally being unreadable and useless.
    However, the latest Windows update does seem to have fixed it for me. Not sure which, because when I look at what I installed on the 17th June 2011 there seems to have been about 20 or so updates that day. But something in there did the trick for me, at least at first glance.
    2011-06-17T09:13:49+00:00
    Yes, I have the same problem
    And the advice from Jay does not help
    The fonts are there in the fonts folder, its just Word 10 that fails to use them in the same way as all previous versions of Word
    Awful bug. I have had to revert to Word 7
    When will Microsft come up with a solution?
    Phil
