A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
I'm not sure I follow the statement that the fonts don't meet the requirements of Word. When did Word introduce requirements narrowing the spectrum of supported fonts to a smaller set than Windows itself? Windows as a whole and all other applications I use have no trouble supporting the Minion font in question.
Further, bearing in mind that this problem did not exist in Word 2003 or the Beta of Word 2010, their reluctance to fix the issue on those grounds--if they even apply--would be a disconcerting technicality.
While Microsoft does not monitor this forum, AdaminVA and perhaps others in this thread have attempted to engage Microsoft directly. While my query to Microsoft may be in vain since they aren't even in the room, so to speak, I nevertheless am eager to hear the latest statement from them. Even if it is delivered by way of an intermediary.
Microsoft does not monitor this forum, so there is little we can tell you other than they now know about the problem.
My guess is that it is unlikely to be fixed because the fonts don’t meet the current requirements to work in Word.
Terry
"zombie010" wrote in message news:*** Email address is removed for privacy ***...
"D Yong" has has posted another message that appears related to this issue. What's the word on this, Microsoft? (No pun intended.)
Terry Farrell
