A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
Hi Jeff, sorry to tell, that this setting won't change the misbehaviour, at least in my case... already tried it. Nor setting the compat.-option to 2003 at all.
Kaj
How did it become checked? That setting is normally unchecked by default.
Terry Farrell - MSWord MVP
"jlp51" wrote in message news:*** Email address is removed for privacy *** .com...
Friends, I have found a little help with the problem, though it has not solved it altogether.
- Open the file you have had font problems with (Open Type fonts have been my problem so far).
- Go to the <File> tab.
- Go to <Options>.
- Go to <Advanced>
- At the very bottom of <Advanced> you should see <Compatibility options for:> and your file in a drop down window to the right of it.
- Click the down arrow that says <Layout Options>
- If you have a checked box that says <Disable OpenType Font formatting features>,UNCHECKthe box.
This did not stop all the problems, but it did make all the spacing problems with the "substituted" fonts behave and leaves me with consistent font spacing.
Hope this helps.
Jeff
Terry Farrell
