A family of Microsoft word processing software products for creating web, email, and print documents.
I solved this problem by saving the troublesome file in what 2010 calls "compatability mode>"
I upgraded from Office 2007 to 2010 two weeks ago. Whenever I open up documents in Print Layout View that were created under earlier versions of Word (2000, 2003, 2007), Word replaces several of the fonts with something that looks like Arial bold.Sometimes it changes just the title fonts, sometime the entire body font--it's not always the same phenomenon in each document.
The Font window on the Home tab still shows the name of the original font being used in the document, but the screen does not show that font--it just shows whatever it replaces the font with. Repeat: even though the screen in showing a different font, the Font window on the Tab Screen shows the name of the font the document should be showing.
When I change to Draft View, the fonts all display properly, but I need the correct fonts in the Print Layout to show because the bogus font that Word substitutes throws off the accuracy of what I'm looking at.
Is anyone else having this problem?
Jeff
Eutactic, I finally tried this solution. I really was not comfortable deleting everything under \Office, but after backing up the registry, I gave it a try. So far it seems to have worked. I will be finishing an important project during the week, so I will have daily opportunities to see how this holds up.
Thanks for the recommendation.
Jeff
I believe I have solved this problem by simply backing up and deleting all the registry values in HKEY_CURRENT_USER\Software\Microsoft\Office. Obviously this is an extreme approach that wiped my preferences, but it appears to have done the trick.
Zombie010, how were you able to post the picture? I would be glad to do the same thing.
Jeff
I've experienced the problem described in this thread on the following platform:
Windows Server 2008 R2 x64 (used as a desktop OS) + Word 2010 64-bit
In fact, you can see a screen-shot of the problem in my thread about Type 1 font support problems in Word 2010 . Here is that screen shot again:
Specifically, for Adobe Type 1 fonts, Word will frequently fail to use the font for rendering. It will use what looks to be Arial instead. This did not seem to happen in the Office 2010 beta. In my experience, this problem crept into the RTM version. The problem also did not exist in Word 2003, the previous version I had used prior to the 2010 Beta.
I definitely think there is a bug here and Microsoft should look into this post haste.
