Word 2010 problem with PostScript Type 1 fonts and PDF export
2010-06-18T19:07:47+00:00
I have been using Office 2010 since the Beta period and I am now using the release build.
I use Adobe Postscript Type 1 fonts regularly in my documents, and I have found that Word 2010 (and presumably all of the Office 2010 applications) has several problems working with PostScript fonts.
Most notably, the "Save as PDF" function will create documents with an odd gradient effect applied to all PostScript fonts.
Secondarily, the Word editor frequently glitches and renders PostScript fonts using a sans-serif font that looks to be Arial.
The following are a demonstration of the issue:
![](http://www.tsotech.com/images/office2010/original-doc-small.jpg)
This is an original document typed in Minion, an Adobe PostScript Type 1 font.
![](http://www.tsotech.com/images/office2010/pdf-version-small.jpg)
This is the document as rendered by muPDF, a very lightweight PDF reader.  Note that the official Adobe Acrobat Reader will render the document correctly.  I suspect Microsoft only tested the PDF export functionality with the Adobe Reader and concluded that it was functioning correctly.  But please note that alternative readers are fairly commonplace, especially with so many security issues being found daily in Adobe's products.
![](http://www.tsotech.com/images/office2010/mac-small.jpg)
I don't have access to a Mac, but the above screenshot was from a Mac's PDF reader attempting to display a different PDF document I had sent a colleague.
Finally, during regular use of Word 2010, the editor will fail to render PostScript Type 1 fonts correctly, falling back on a sens-serif font that I believe to be Arial.  See below:
![](http://www.tsotech.com/images/office2010/display-glitch-small.jpg)
Please investigate these issues, Microsoft!
2010-09-09T05:13:08+00:00
There are 4 issues in this thread for Word 2010 RTM:
  1. Some PostScript fonts display incorrectly after being edited in Word's Print Layout.
  2. Documents with some (but not all) fonts containing PostScript outline data (Ex: Helvetica, Times) crash on open.
  3. Documents using fonts with PostScript Outline data saved as a PDF in Word render correctly in Adobe Reader but incorrectly in some other PDF Viewers.
  4. Documents using fonts with PostScript outline data saved as a PDF in Word render the text as a static image rather than selectable text.
Issue #1
To assist us in solving this issue, please answer the following questions. Thank you.
  1. What is the full name for the printers you have installed? Which of these is the default printer? [Start -> Type "Devices and Printers"]
  2. What editing languages do you have enabled in Word? [Open Word -> File -> Options -> Language]
  3. When in a corrupt state, does changing to a different printer (and back) fix the issue? [File -> Print]
  4. Can you reproduce the issue in *.doc files? [File -> Save As -> Save as type = "Word 97-2003 Document (*.doc)"]
  5. Can you reproduce the issue in *.docx files?  [File -> Save As -> Save as type = "Word Document (*.docx)"]
  6. Can you reproduce the issue in Draft View? [View ->Draft View]
  7. Can you reproduce the issue in both Portrait and Landscape orientations? [Page Layout -> Orientation]
  8. Can you reproduce the issue in a version of Windows earlier than Windows 7 / Windows 2008?
  9. Can you reproduce the issue in a version of Word earlier than Word 2010?
Here are several workarounds for this issue from my other thread, but please continue to assist us by answering the questions above. Workarounds in order of most convenient to least convenient are:
  1. Add a Right-to-Left language, such as Hindi, to your list of editing languages. [(In Word) File -> Options -> Language -> [Add aditional editing languages] -> Hindi -> Add]
  2. Each time a document is opened with the incorrect font being displayed change to a different printer (and back). [(In Word) File -> Print]
  3. Uninstall all printers from Windows. [(In Windows) Start -> Devices and Printers]
Issue #2
Problem A – Use one of these workarounds if you are crashing when opening documents with fonts Helvetica or Times.
  • Remove offending PostScript font substitutions from the registry location. Restart computer.
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes]
  • Install the OpenType versions of the offending PostScript fonts.
  • Uninstall the offending PostScript fonts.
  • Open the Font Dialog Box (Ctrl + D) before attempting to display an offending PostScript font. This fix lasts until Word is closed.
Problem B – Use one of these workarounds if you are crashing when opening documents with fonts other than Helvetica or Times. In this case you are most likely crashing due to your printer driver.
  • Change your default printer to another printer that does not crash (ex: Microsoft XPS Document Writer).
  • Uninstall your printer (or all printers).
Issue #3
Currently the best workaround is the one already given by the original poster: Open your PDF documents in Adobe Reader rather than muPDF or the Mac's default PDF reader.
Issue #4
When saving documents using fonts with PostScript outline data, Word 2010 only supports outputting the text as a static image, and does not support outputting the text as selectable text. Currently the best workaround is the one already given by the original poster: Use a printer driver that outputs to PDF such as Adobe Acrobat or CutePDF.
-Omega
61 additional answers
    2010-07-03T16:34:08+00:00
    I'll grant you that PDF being more of an Adobe property than a truly open format makes it something subject to interpretation.  And in that sense, you're correct that Adobe Reader is the "reference" implementation and if your program that generates PDFs works with Reader, you can rightfully call your files "PDF files."
    That said, PDF is intended to be a format for portability.  It's what the "P" stands for, after all.  Recognizing that Adobe Reader has been the subject of a disproportionate number of attacks and has been demonstrated to be composed of code written without security as an objective, there is a small but growing contingent of people who will resist using it.  Just as people are growing weary of Flash (for myself avoiding Flash is principally because, again, it has been the cause of a large number of desktop/workstation compromises), making alternatives more serious contenders, I think Adobe Reader can't be considered the only player in the PDF reader space.
    You are right that it is possible that both the Mac OS X reader and muPDF have misinterpreted the PDF file format.  But given the evidence my bet is on Microsoft writing bad PDF files, especially when considering it seems to be based on the use of Type 1 fonts--something that given my admittedly limited understanding of PDF, I suspect should not really come into play once we're at the point where we have a PDF file with font-glyph data embedded.
    You say the PDF generating code ignores some of the basic rules set by Adobe.  What is more likely?  (a) that one or more of those rules say, "Don't render a gradient alpha channel in lines of text."  Or (b) two (possibly related but unknown) PDF readers on two separate platforms render the PDF files with gradient effects.  Mind you, one shows the text (muPDF) while the other renders as mostly white with some gradient rectangles (Mac OS X PDF reader).
    I think you're with me that (a) is more likely and you're just pointing out that (b) is a possibility.  And I agree.
    But given that Microsoft can't even render Type 1 fonts correctly **on screen**, I am going to go with (a).
    2010-07-03T15:21:34+00:00
    The reader is called Adobe Reader these days (not Acrobat Reader). And MS license their PDF solution from Adobe.
    I didn't know that they had licensed it from Adobe.  Do you take it that they actually licensed the PDF generation code from Adobe or that they are merely paying Adobe a licensing fee for the right to generate PDF files directly within a commercial product?
    Considering the pdf generating code ignores some of the basic rules for pdfs set by Adobe, I doubt they got the code from Adobe.
    Regardless, there is a compatibility issue and it is demonstrably not isolated to muPDF:
    • Using Type 1 or TrueType fonts, Adobe Acrobat generates PDF files that are readable on Adobe Reader, muPDF, and the Mac OS X PDF reader.
    • Using Type 1 fonts, Word 2010 generates PDF files that are readable on Adobe Reader, butnot compatible with muPDF or the Mac OS X PDF reader.
    • Using TrueType fonts, Word 2010 generates PDF files that are readable on Adobe Reader, muPDF, and the Mac OS X PDF reader.
    In fact, if this issue were isolated to muPDF, I wouldn't care at all.  muPDF is simply what I use on my PC because Acrobat Reader, like Flash, is a commonly targeted and historically highly vulnerable product.  This issue existed in the Office 2010 Beta and I didn't report it because at that time, I thought it was a muPDF defect.  No, the real reason I am here continuing my effort to keep this in front of Microsoft is that the default Mac OS X PDF reader cannot read PDF files I generate with Type 1 fonts from Word 2010.  When I send PDF files to colleagues that use Macs, they reply with, "Uh, what was that?"  I can't blame them, looking at the screen-shots I've taken of the Mac reader trying to render a Word 2010 Type 1 PDF.
    As Adobe, the inventor of the pdf format, is displaying the files correctly in their software, one can argue that the problem must be with the other viewers and not with the pdf documents. I don't say it is, but it is something to consider.
    On top of that, it is likely that Apple got its pdf viewing capabilities somewhere through the unix open source community. And as muPDF is open source and contains unix traces at first glance (x11, ...), I wouldn't be surprised if they both use or have used the same code base. Hence, presenting the same (incorrect) result.
    2010-07-03T14:58:51+00:00
    2010-07-01T07:14:13+00:00
