Tried to login to outlook. Received Error code: STATUS_STACK_OVERFLOW
2024-06-14T09:50:15+00:00
Tried to login to outlook. Received Error code: STATUS_STACK_OVERFLOW. Screen said, "Refresh page". I did several times, same error code keep appearing. I shut down my pc and restarted. Logged in again to Outlook. I use "Live.com.au" , Same above message. On another pc, I can log on to my outlook account - PLEASE HELP
2024-06-15T23:06:43+00:00
WORKAROUND - download firefox browser and install- Everyone who is having this problem is on a windows 7 computer , the same crash happens on internet explorer browser or chrome browser. i have 2 diffrent windows 7 pc's and it is only happening on one of them which is a dell optiplex 780 . i installed firefox and i was able to open emails in outlook on the problem computer . the problem is in MSN outlook coding.
217 additional answers
    2024-09-03T23:08:38+00:00
    will it work if put 64bit windows on 32bit?
    2024-09-04T01:02:43+00:00
    Hope you won't take this the wrong way, but if I'm to assume that you meant replacing your 32-bit Windows with the 64-bit version, the way you worded that question makes me say that you shouldn't try, since we're talking about reinstalling the OS from scratch, and if that OS is Win 7 then getting a fresh install fully up to date (as far as updates existed) and properly operational with all drivers and everything now would be a daunting prospect even for advanced users.
  3. Deleted
    2024-09-04T04:34:05+00:00
    32 or 64 is the processer speed, I don't think you can install 64 on a 32, you might be able to put 32 on a 64 though with a bios change but I am not expert on them biscuits. Also might be able to put a chome operating system on them but it might be a lot of work
