Tried to login to outlook. Received Error code: STATUS_STACK_OVERFLOW
2024-06-14T09:50:15+00:00
Tried to login to outlook. Received Error code: STATUS_STACK_OVERFLOW. Screen said, "Refresh page". I did several times, same error code keep appearing. I shut down my pc and restarted. Logged in again to Outlook. I use "Live.com.au" , Same above message. On another pc, I can log on to my outlook account - PLEASE HELP
2024-06-15T23:06:43+00:00
WORKAROUND - download firefox browser and install- Everyone who is having this problem is on a windows 7 computer , the same crash happens on internet explorer browser or chrome browser. i have 2 diffrent windows 7 pc's and it is only happening on one of them which is a dell optiplex 780 . i installed firefox and i was able to open emails in outlook on the problem computer . the problem is in MSN outlook coding.
217 additional answers
    2024-07-02T15:47:30+00:00
    Firefox work around has stopped working now, time to switch to Gmail
    2024-07-02T22:01:29+00:00
    Firefox still works for me but is slow. Supermium works ok for me with Outlook, and is very easy to instal and sync.
    2024-07-03T09:42:24+00:00
    However, the solution should be very simple: On June 13, it was still working. On June 16, it no longer worked. This means that between these two dates, you did something to your Outlook programming that caused the problem. Undo everything you did between these two dates and everything should be back to normal!
    2024-07-03T10:44:45+00:00
    @Semajee - thanks for the tip. An older Firefox was working "ok", but I just tried to install Supermium this morning and it works fine - fast enough as of now - with my usual tabs open there, including Outlook. The installation was fast and the syncing too.
    Just to be clear to others that answer my original concern - I DO NOT WORK FOR MICROSOFT. I'm in the same cunumdrum as all of you. Thanks.
