Tried to login to outlook. Received Error code: STATUS_STACK_OVERFLOW
2024-06-14T09:50:15+00:00
Tried to login to outlook. Received Error code: STATUS_STACK_OVERFLOW. Screen said, "Refresh page". I did several times, same error code keep appearing. I shut down my pc and restarted. Logged in again to Outlook. I use "Live.com.au" , Same above message. On another pc, I can log on to my outlook account - PLEASE HELP
2024-06-15T23:06:43+00:00
WORKAROUND - download firefox browser and install- Everyone who is having this problem is on a windows 7 computer , the same crash happens on internet explorer browser or chrome browser. i have 2 diffrent windows 7 pc's and it is only happening on one of them which is a dell optiplex 780 . i installed firefox and i was able to open emails in outlook on the problem computer . the problem is in MSN outlook coding.
217 additional answers
    2024-06-17T17:40:22+00:00
    I am having the same problem in Argentina. My Chrome version is 109.0.5414.120 (Build oficial) (32 bits)
    2024-06-17T18:09:50+00:00
    Version 108 is also affected, since that's what I have listed as the Chromium version used by the Vivaldi version that I'm using (5.6, the last one that works on Win 7).
    2024-06-17T18:22:15+00:00
    Would you happen to know how to fix this problem?
    2024-06-17T20:42:33+00:00
    In a Chromium-based browser, no. The (I hope temporary) workaround is the one also stated by the support rep, to use Firefox (or a Firefox fork) for the time being. I can log in on the current version of Pale Moon Portable (an older one that I had didn't work). It's slow and a system resource hog, but you can just run it without actually installing it on the system, so if you don't want to keep another browser it's an option, and maybe they'll fix the issue soon enough.
