Configuring preferences and options in Outlook.com
YAY! Now I can just fire that sound myself when I notice an unread email!
(Yes, I'm being snarky. Thanks for sharing some info, though.)
UPDATED AS OF OCTOBER 16TH, 2024
I AM NOT GETTING THE SOUND NOTIFICATIONS AGAIN :( This is after my pc was updated (microsoft windows). It also is affecting my fingerprint sensor. It does not work anymore. I have to login by typing my PIN :(
UPDATED as of August 23rd, 2024
HELLO EVERYONE! My email notification sound is BACK. I did not do anything. It just happened today when I logged in. I am using web outlook and chrome browser. I honestly did not make any changes with my settings. So, I guess, Microsoft has already fixed this. Please check yours
Hello!
I started experiencing this just today. I have been using outlook web for almost two years now and it just happened today. I have turned on all notif as well as in my Google chrome browser, and my pc. All notif has been turned on.
I have also refreshed the settings by turning it off and on, restarted my pc twice today, nothing works.
I have signed in to another outlook account which I also owned for work, and it is doing just fine. Notif sound is working. But in my main email, the email I am using in posting this, is not working at all. Please help. I need the notif sound so I could action all email requests at work on time.
HELLO EVERYONE! My email notification sound is BACK. I did not do anything. It just happened today when I logged in. I am using web outlook and chrome browser. I honestly did not make any changes with my settings. So, I guess, Microsoft have already fixed this. Please check yours
Same here with this all of a suddent stopping. But with mine, it does not work in Chrome, but it works just fine in Firefox. Go fiugre.
Hi Everyone,
I believe I’ve found a possible solution for the notification sound issue. I was able to get notification sounds by enabling the "sync across Microsoft 365" setting. While it might seem unrelated, it worked for me.
Here are the steps:
Please test this solution and let me know if it works for you as well.
Best,
Hi Everyone,
Here are the steps:
- Go to settings (gear icon)
- Select General
- Language and Time
- Turn on “sync across Microsoft 365” and reload
Best,
Yeah, this seems to work, at least for me
Thanks @Jake Hagemann
Just tested and this worked for me, ironically I had JUST found another fix by using Firefox with an Notification Sound add-on by freaktechnik, but I would prefer not to use an add-on so THANK YOU SO MUCH!
