Using the New Outlook for Mac features in business environments
I can recieve emails but cant send any
My Outlook account is not downloading or sending messages. I am able to login and I have used the sync button. Anyone else had this happen and know how to resolve it? I've used the Microsoft help and it was not helpful at all!
I FIXED IT. you need to be sure to reinstall all components of your office program if you have office 2024, I had not installed the excel.. components outlook be sure to use old outlook style version. new version (focus and other) will not work. my system automatically set my email configurations. I am up and running.
I use an external hard drive its cheaper.
you need to reinstall your outlook, me new computer did the same thing, I purchased office 2024, and it work . older version doesn't. make sure you use old style outlook not new style.
I HAD 2014. Not pass 10 years go figure., you don't need 365 subscription unless you want it., just go by office home and business version $249. it contains word,excel,powerpoint,onenote,outlook
