Why does Microsoft Outlook keep asking for Password
2024-01-31T21:23:19+00:00
Why does Microsoft Outlook keeps constantly asking for Password. I even had to change my password thinking it would help. It didn't. Even after I enter password, still continues prompting me to enter password. Just does not go away. And it is also affecting my account with Spectrum Roadrunner to perform other functions that I was able to do without having to enter a password. This problem just recently started and Spectrum can't help since it's a Microsoft issue causing the problem. Tried to get help by calling Microsoft by using the recommended website since I'm unable to get a live person to talk to, but the website Microsoft is directing to go for HELP wants to charge a Fee plus a monthly fee. We purchased Microsoft. Didn't use to have this issue
    2024-10-25T06:26:18+00:00
    I had the same issue. I uninstalled MS Office 2016 Pro Plus completely and went over the control panel in the mail section if I can call it that. I set up the profiles, and I believe that solved the issue. Fingers crossed. There have been no pop-ups yet.
    2024-10-25T17:03:58+00:00
    I just did what you suggested and it did NOT work, in fact, now can't even access outlook!!!
    "Remove your credentials from the Credentials Manager: Open the Control Panel and navigate to User Accounts > Credential Manager. Under Windows Credentials, locate any entries for Outlook and click Remove. Restart Outlook and enter your login credentials again"
    This does NOT work. In fact, it will deny you access to your outlook pst file!!! Clearly, you are suggesting things you've never done yourself. Shame on YOU!
    2024-11-12T09:12:16+00:00
    I have the same problem as Barry. The problem arose after I decided to try the new Outlook.
    After I tried the new Outlook and switched back, classic Outlook started asking for a password all the time (even after successfully authenticating with the Microsoft Authenticator app). Outlook stopped syncing my profile, while two other profiles (Google and Work and school account) sync normally, fortunately for them I did not try the new Outlook
    2024-11-12T09:29:51+00:00
    this about sums up the issue between outlook classic and new perfectly. One can only hope that MS support are paying attention!?!?!?
    2024-11-13T22:58:00+00:00
    Same issue, thinking to avoid Microsoft Outlook.
