how do I block all emails ending with @jean-patrique.co.uk.
2023-11-13T13:55:33+00:00
How do I block all emails ending with @jean-patrique.co.uk. So annoying - keep receiving them every 10 minutes if not often. In 2 days - 300 emails. Did try to make a email rule, but doesnt help. Any ideas?
2023-11-21T22:02:32+00:00
EDIT: 16/12/2023 - a bug with the blocked and safe senders and domains lists was preventing the procedure below from working between 12th and 16th December 2023. This has now been fixed.
There is an easier solution:
  1. Log into Outlook in either the web browser or the windows Outlook app;
  2. Click on the 'cog' symbol towards the top right;
  3. Click on "Email";
  4. Click on "Junk email";
  5. Under "Blocked senders and domains" click "+Add";
  6. Type "jean-patrique.co.uk";
  7. Press 'Enter';
  8. Click "Save" at the bottom of the list.
You can check it has saved the domain by starting to type it into the search bar on the right and it should appear even before you have typed it out in full.
This way it does not matter what combination of characters that the scumbag puts in front of the '@', the spam will get caught by this domain. Even better, unlike rules, which only apply to the inbox, this applies equally to junk email, which is where I presume this spam is going, and the result is to block it completely so you won't see it at all - not even in deleted or recoverable items. This is a positive change from previously, where I believe it just ensured that blocked senders and domains went into the junk folder.
This particular gambling-obsessed scumbag changes their domain every so often - they were ******@emails.fenwick.co.uk then ******@xixvodka.com then @monsoon.co.uk then @e.newscientist.com, so you will probably need to enter another domain if the deluge resumes under another guise.
Hope this helps,
Cheers,
TE
101 additional answers
    2023-12-16T10:18:47+00:00
    I’ve had one ‘gambling’ email this morning, but not from Jean-patrique. I can’t see the usual domain, it merely states “"Casino deal" <Casino deal>”. It may still be from him of course! If I get any more, I will try blocking that. At the moment I’ve just tried ‘block this sender’ on my iPad, rather than go into Outlook.
    I agree you will get the odd one from other spammers. Fortunately, you can still add new addresses by right-clicking on an email >block > block sender, but it then won't be possible to edit it to only the domain, so it will only be useful if the spammer uses the same sender address with no wildcard elements.
    I am in discussion with Outlook via X. They claim this is the first they have heard of the issue. I have confirmed to them that:
    1. It occurs across browsers and the app;
    2. Clearing cache and cookies makes no difference;
    3. Logging out and back in again makes no difference;
    4. Rebooting and installing any windows updates makes no difference.
    On the other thread I linked to, an Independent Advisor has stated:
    I will update if I get any additional information.
    Cheers,
    TE
    2023-12-16T11:22:59+00:00
    Thank you for all your efforts on this.
    2023-12-16T14:00:02+00:00
    Hi all,
    It appears that the issue has been fixed! I have tested it on Firefox browser and the Windows desktop Outlook app.
    I will update the first post again. Hopefully it is business as usual from now on.
    Cheers,
    TE
    2023-12-19T12:24:53+00:00
    I have received 374 emails from @jean-patrique.co.uk all relating to online gaming and gambling websites. I have followed the advice given and blocked the domain. I complained to the company who deny they have been sending them. Clearly their email account has been hacked, cloned, spoofed, or compromised. I am also receiving spam/junk emails from a lot of US based websites, e.g. TEMU, scartinx.com, etc. which I am also blocking.
