how do I block all emails ending with @jean-patrique.co.uk.
2023-11-13T13:55:33+00:00
How do I block all emails ending with @jean-patrique.co.uk. So annoying - keep receiving them every 10 minutes if not often. In 2 days - 300 emails. Did try to make a email rule, but doesnt help. Any ideas?
2023-11-21T22:02:32+00:00
EDIT: 16/12/2023 - a bug with the blocked and safe senders and domains lists was preventing the procedure below from working between 12th and 16th December 2023. This has now been fixed.
There is an easier solution:
  1. Log into Outlook in either the web browser or the windows Outlook app;
  2. Click on the 'cog' symbol towards the top right;
  3. Click on "Email";
  4. Click on "Junk email";
  5. Under "Blocked senders and domains" click "+Add";
  6. Type "jean-patrique.co.uk";
  7. Press 'Enter';
  8. Click "Save" at the bottom of the list.
You can check it has saved the domain by starting to type it into the search bar on the right and it should appear even before you have typed it out in full.
This way it does not matter what combination of characters that the scumbag puts in front of the '@', the spam will get caught by this domain. Even better, unlike rules, which only apply to the inbox, this applies equally to junk email, which is where I presume this spam is going, and the result is to block it completely so you won't see it at all - not even in deleted or recoverable items. This is a positive change from previously, where I believe it just ensured that blocked senders and domains went into the junk folder.
This particular gambling-obsessed scumbag changes their domain every so often - they were ******@emails.fenwick.co.uk then ******@xixvodka.com then @monsoon.co.uk then @e.newscientist.com, so you will probably need to enter another domain if the deluge resumes under another guise.
Hope this helps,
Cheers,
TE
101 additional answers
    2023-12-13T13:52:10+00:00
    Golden Lion, Spicey Jackpot and WinnerCassino all coming through, at least 2/hour, all bot generated, and my version of outlook does not support rules based email handling, Please can anyone tell me how to get back to the old outlook classic.... windows 10 and office 14.... The guidance on the web and forums only relates to later versions and is not possible with my versions... I'll never let microsoft update anything again.
    Are you able to sign into your account using a web browser:
    https://www.microsoft.com/en-gb/microsoft-365/outlook/email-and-calendar-software-microsoft-outlook?deeplink=%2fowa%2f%3frealm%3doutlook.com&sdf=0
    Cheers,
    TE
    2023-12-13T15:14:40+00:00
    Hi, I always go in through google, outlook, log in.
    David
    2023-12-13T15:45:06+00:00
    David
    If you can sign in through the link I posted, hopefully you should be able to access the blocking options as described on the first post in the browser or the windows app. You can then enter the domain to be blocked and exit the browser or app. It ought to then continue to apply to your account, even if you go back to accessing it the way you have been.
    Cheers,
    TE
    2023-12-13T20:37:35+00:00
    After numerous suggestions, and trying everything, I give up on microsoft. Nothing works, Microsoft cant help, the community cant tell me how to sort it...
