how do I block all emails ending with @jean-patrique.co.uk.
2023-11-13T13:55:33+00:00
How do I block all emails ending with @jean-patrique.co.uk. So annoying - keep receiving them every 10 minutes if not often. In 2 days - 300 emails. Did try to make a email rule, but doesnt help. Any ideas?
2023-11-21T22:02:32+00:00
EDIT: 16/12/2023 - a bug with the blocked and safe senders and domains lists was preventing the procedure below from working between 12th and 16th December 2023. This has now been fixed.
There is an easier solution:
  1. Log into Outlook in either the web browser or the windows Outlook app;
  2. Click on the 'cog' symbol towards the top right;
  3. Click on "Email";
  4. Click on "Junk email";
  5. Under "Blocked senders and domains" click "+Add";
  6. Type "jean-patrique.co.uk";
  7. Press 'Enter';
  8. Click "Save" at the bottom of the list.
You can check it has saved the domain by starting to type it into the search bar on the right and it should appear even before you have typed it out in full.
This way it does not matter what combination of characters that the scumbag puts in front of the '@', the spam will get caught by this domain. Even better, unlike rules, which only apply to the inbox, this applies equally to junk email, which is where I presume this spam is going, and the result is to block it completely so you won't see it at all - not even in deleted or recoverable items. This is a positive change from previously, where I believe it just ensured that blocked senders and domains went into the junk folder.
This particular gambling-obsessed scumbag changes their domain every so often - they were ******@emails.fenwick.co.uk then ******@xixvodka.com then @monsoon.co.uk then @e.newscientist.com, so you will probably need to enter another domain if the deluge resumes under another guise.
Hope this helps,
Cheers,
TE
101 additional answers
    2023-12-13T09:54:52+00:00
    I keep asking myself “what do these people gain from spamming other people’s emails”. Why do they do it?
    2023-12-13T10:40:08+00:00
    like the top one ......
    I can not understand how do these emails slip in still? Once domain blocked, it stopped but some random "spicy" patrique still coming in ...
    2023-12-13T12:14:23+00:00
    I don’t know. I can tolerate one or two, but 100 a day was getting too much. It’s been 24 hours since I blocked the domain, and nothing has come in at all. All good so far.
    2023-12-13T13:41:14+00:00
    Golden Lion, Spicey Jackpot and WinnerCassino all coming through, at least 2/hour, all bot generated, and my version of outlook does not support rules based email handling, Please can anyone tell me how to get back to the old outlook classic.... windows 10 and office 14.... The guidance on the web and forums only relates to later versions and is not possible with my versions... I'll never let microsoft update anything again.
