how do I block all emails ending with @jean-patrique.co.uk.
2023-11-13T13:55:33+00:00
How do I block all emails ending with @jean-patrique.co.uk. So annoying - keep receiving them every 10 minutes if not often. In 2 days - 300 emails. Did try to make a email rule, but doesnt help. Any ideas?
2023-11-21T22:02:32+00:00
EDIT: 16/12/2023 - a bug with the blocked and safe senders and domains lists was preventing the procedure below from working between 12th and 16th December 2023. This has now been fixed.
There is an easier solution:
  1. Log into Outlook in either the web browser or the windows Outlook app;
  2. Click on the 'cog' symbol towards the top right;
  3. Click on "Email";
  4. Click on "Junk email";
  5. Under "Blocked senders and domains" click "+Add";
  6. Type "jean-patrique.co.uk";
  7. Press 'Enter';
  8. Click "Save" at the bottom of the list.
You can check it has saved the domain by starting to type it into the search bar on the right and it should appear even before you have typed it out in full.
This way it does not matter what combination of characters that the scumbag puts in front of the '@', the spam will get caught by this domain. Even better, unlike rules, which only apply to the inbox, this applies equally to junk email, which is where I presume this spam is going, and the result is to block it completely so you won't see it at all - not even in deleted or recoverable items. This is a positive change from previously, where I believe it just ensured that blocked senders and domains went into the junk folder.
This particular gambling-obsessed scumbag changes their domain every so often - they were ******@emails.fenwick.co.uk then ******@xixvodka.com then @monsoon.co.uk then @e.newscientist.com, so you will probably need to enter another domain if the deluge resumes under another guise.
Hope this helps,
Cheers,
TE
101 additional answers
    2023-12-12T23:09:32+00:00
    I'm sorry but that does not work, keep getting told new outlook does not support rules (im on windows 10 running office 14 )
    Tried the solution suggested, and several others... thanks everyone for trying. I cant seem to get back to the old version of outlook, that did support rules. All the optons are not available and the outlook.exe that used to run it is nolonger in my program files. Think microsoft may have removed it as part of the update....
    Thanks again
    David
    Are you able to log into your account using outlook.live.com or the outlook app on windows where the options that have been discussed exist?
    Cheers,
    TE
    2023-12-12T23:14:34+00:00
    I’m sorry, but your reply is far too technical for me! All I’ve done is block Jean-patrique.co.uk for my junk email, and now hope for the best. Failing that, my technical expertise and knowledge doesn’t enable me to do any more. I wouldn’t know about ISPs for instance. You’d think Microsoft could deal with this…..
    2023-12-13T09:18:09+00:00
    Yes, I usually have mail on iPad, but in this case I logged onto outlook.live on my Chrome browser. Went onto the little cog wheel, selected Junk Mail and blocked simply jean-patrique.co.uk. (without the @)
    I’m pleased to report that I’ve not received anything from this person since then….so it seems to be working so far. However, someone did say yesterday that they’d had success but that the emails started up again after a couple of weeks, so we shall see!
    2023-12-13T09:32:45+00:00
    I am pleased that it is working for you. You may find that you do receive the odd one or two that don't match the filter, but this doesn't mean that the filter isn't working and will continue to block any that match it. I received two yesterday, for reasons suggested in previous posts. The other thing that may eventually happen is that the spammer changes the domain, in which case it should be possible to block the new domain in the same way.
    Cheers,
    TE
