how do I block all emails ending with @jean-patrique.co.uk.
2023-11-13T13:55:33+00:00
How do I block all emails ending with @jean-patrique.co.uk. So annoying - keep receiving them every 10 minutes if not often. In 2 days - 300 emails. Did try to make a email rule, but doesnt help. Any ideas?
2023-11-21T22:02:32+00:00
EDIT: 16/12/2023 - a bug with the blocked and safe senders and domains lists was preventing the procedure below from working between 12th and 16th December 2023. This has now been fixed.
There is an easier solution:
  1. Log into Outlook in either the web browser or the windows Outlook app;
  2. Click on the 'cog' symbol towards the top right;
  3. Click on "Email";
  4. Click on "Junk email";
  5. Under "Blocked senders and domains" click "+Add";
  6. Type "jean-patrique.co.uk";
  7. Press 'Enter';
  8. Click "Save" at the bottom of the list.
You can check it has saved the domain by starting to type it into the search bar on the right and it should appear even before you have typed it out in full.
This way it does not matter what combination of characters that the scumbag puts in front of the '@', the spam will get caught by this domain. Even better, unlike rules, which only apply to the inbox, this applies equally to junk email, which is where I presume this spam is going, and the result is to block it completely so you won't see it at all - not even in deleted or recoverable items. This is a positive change from previously, where I believe it just ensured that blocked senders and domains went into the junk folder.
This particular gambling-obsessed scumbag changes their domain every so often - they were ******@emails.fenwick.co.uk then ******@xixvodka.com then @monsoon.co.uk then @e.newscientist.com, so you will probably need to enter another domain if the deluge resumes under another guise.
Hope this helps,
Cheers,
TE
101 additional answers
    2023-12-11T10:21:07+00:00
    HI
    Can you please tell me how to stop over 50 spam mails everyday from this **** jean patirque, i have blocked, reported even changed the rule to no avail, he is doing my head in now please someone in great detail explain to me how to stop him
    1. Log into Outlook in either the web browser or the desktop app;
    7. Press 'Enter';
    If you have lots of items on your blocked list, you can check it has added it by starting to type "jean-patrique.co.uk" in the search bar to the right of "+Add" and it should appear on the blocked list below.
    I hope that helps.
    Cheers,
    TE
    2023-12-12T09:44:20+00:00
    Rukes used to work, but now on the new version of outlook, rules DO NOT WORK, thanks Microsoft, You want us all on 365, but sorry, no way, off to Libre Office, if I've got to pay for something, I'm not paying for being messed up by you, ( 20 spam emails from gambling websites an hour, sometimes 3 per minute???)
    2023-12-12T09:50:43+00:00
    Hi Ajibola,
    Tried your advice, but new version of outlook, on office 14, does not support rules, they just don't work, been trying to get back to the old version, where rules did work, any thoughts please?
    David
    2023-12-12T13:34:48+00:00
    This person has inundated my junk email box for weeks (over 100 in the last 12 hours), so I did exactly the process above (using *@jean-patrique.co.uk to over anything he puts before the domain name). However, they are still coming in, and I’ve checked again, only to see this on Microsoft’s page..
    “You can block messages from specific email addresses or domains from reaching your inbox. When you add an email address or domain to your blocked senders list, Outlook automatically moves messages from that sender to the Junk Email folder.”
    I want them blocked completely, not merely moved to my junk mailbox.
    Can this be done, do you know?
    Thank you!
