how do I block all emails ending with @jean-patrique.co.uk.
2023-11-13T13:55:33+00:00
How do I block all emails ending with @jean-patrique.co.uk. So annoying - keep receiving them every 10 minutes if not often. In 2 days - 300 emails. Did try to make a email rule, but doesnt help. Any ideas?
2023-11-21T22:02:32+00:00
EDIT: 16/12/2023 - a bug with the blocked and safe senders and domains lists was preventing the procedure below from working between 12th and 16th December 2023. This has now been fixed.
There is an easier solution:
  1. Log into Outlook in either the web browser or the windows Outlook app;
  2. Click on the 'cog' symbol towards the top right;
  3. Click on "Email";
  4. Click on "Junk email";
  5. Under "Blocked senders and domains" click "+Add";
  6. Type "jean-patrique.co.uk";
  7. Press 'Enter';
  8. Click "Save" at the bottom of the list.
You can check it has saved the domain by starting to type it into the search bar on the right and it should appear even before you have typed it out in full.
This way it does not matter what combination of characters that the scumbag puts in front of the '@', the spam will get caught by this domain. Even better, unlike rules, which only apply to the inbox, this applies equally to junk email, which is where I presume this spam is going, and the result is to block it completely so you won't see it at all - not even in deleted or recoverable items. This is a positive change from previously, where I believe it just ensured that blocked senders and domains went into the junk folder.
This particular gambling-obsessed scumbag changes their domain every so often - they were ******@emails.fenwick.co.uk then ******@xixvodka.com then @monsoon.co.uk then @e.newscientist.com, so you will probably need to enter another domain if the deluge resumes under another guise.
Hope this helps,
Cheers,
TE
101 additional answers
    2023-12-08T16:15:51+00:00
    OK, what you need to do is click on "+Add" first, then type "jean-patrique.co.uk" then press enter and a "save" button will appear at the bottom for you to click on. Once you have done that if you start typing "jean-patrique.co.uk" in the search bar as I have done above it should appear on the list.
    Cheers,
    TE
  2. Deleted
    2023-12-09T00:24:02+00:00
    How do I leave this question so I don’t get all the replies?
    Off the top of my head, there are two things you could try in the following order:
    1. Replying again and unchecking the box "Notify me when someone responds to this post". This may override any earlier instruction to be notified.
    2. Going back to your original response and clicking edit and then delete.
    Cheers,
    TE
    2023-12-11T10:04:46+00:00
    HI
    Can you please tell me how to stop over 50 spam mails everyday from this **** jean patirque, i have blocked, reported even changed the rule to no avail, he is doing my head in now please someone in great detail explain to me how to stop him
