How I can switch from working offline to working online in outlook?
2023-12-12T23:30:47+00:00
    2025-05-16T23:27:57+00:00
    I have tried and it won't change from offline
    2025-05-18T17:40:55+00:00
    I cannot get back online in Outlook.
    I cannot just click on preferences it does not work
    2025-05-27T21:02:30+00:00
    Hello Arquel. What can I do when the Work Offline button does not change when I click on it?
  4. Hal Hostetler MVP-Outlook 12,011 Reputation points MVP Volunteer Moderator
    2025-05-27T21:40:35+00:00
    If Working offline is enabled, click the button *once* and wait a few minutes for it to reconnect. Note from the image, the red X will NOT go away, the button highlight will clear.
    2025-05-28T21:53:53+00:00
    Thank you very much. It worked!
