How I can switch from working offline to working online in outlook?
2023-12-12T23:30:47+00:00
    2024-09-14T22:37:20+00:00
    I am still having the same problem. The "Work Offline" box has a red X in it and I cant change to working online.
    2024-09-23T21:58:11+00:00
    I cannot turn Microsoft Outlook from 'offline' to 'online.'
    2024-09-23T21:59:26+00:00
    I cannot turn Microsoft Outlook from 'offline' to 'online' and I have tried the Control Panel, but there is no way to turn offline to online
    2024-09-26T21:03:21+00:00
    Can not switch work offline to work online
    2024-09-27T07:28:39+00:00
    Hello Rimma,
    Thank you for posting here in Microsoft Community.
    To answer your question, here's how to switch from working offline to working online in Outlook, please follow these steps:
    1. Open Outlook.
    2. Click on the "Send/Receive" tab in the top menu.
    3. Look for the "Work Offline" button in the "Preferences" section.
    4. If the button is highlighted, click on it to turn off the "Work Offline" mode.
    5. Once you have turned off the "Work Offline" mode, Outlook will start to synchronize with the server and you will be able to send and receive emails.
    You may also refer to this article: Work offline in Outlook - Microsoft Support
    If you are still having issues switching from working offline to working online, please let me know and I will be happy to assist you further.
    Best regards,
    Arquel C.
    Microsoft Moderator
    I click the OFF LINE button in Outlook and there is no change!!!
    Can you please help me change to Outlook ONLINE
    Many thanks
    K. Joan Dold
