Well, I’m pushing in the emails that come into Hotmail/Outlook from Hotmail to Gmail. I do that from Settings/Mail/Forward and IMAP. They are all going to Gmail just fine, even those coming into my Outlook aliases in Hotmail.
It is when I then send from Gmail under the name of one of those aliases (they come into gmail as from the alias, so clicking the Reply button sets them up to respond to the sender via the same alias address. I believe I can initiate a new e-mail via an Outlook alias too, although I don’t generally do that.)
We have been talking about the settings in Outlook for that.
I do also have both POP and IMAP set up in Gmail. That is under Settings/Forwarding and POP/IMAP. My configuration has been unchanged for many years now. It is only earlier this year that this problem started.
But first, what we are talking about is under the Accounts and Import tab instead. The Forwarding and POP/IMAP tab seems to be merely for forwarding my Gmail e-mail. I believe I did that when I had some issue about e-mail in Gmail that was not in Outlook. It id not sending all my Gmail to Outlook.
Under Accounts and Import, under Snd mail as:, I do have the Outlook aliases listed there. That is where I have been trying to get the settings right all through this discussion.
The default setup there is to send as my main Hotmail address. That works fine. It’s those Outlook aliases that do not work anymore, they used to. The one I have been using in recent times is sent with :
Mail is sent through: smtp.office365.com
Secured connection on port 587 using TLS
And I have explained the issue with even trying to change the SMTP setting.
On another, which I have not used in a long time, it is set as:
Mail is sent through: smtp.live.com
Secured connectin on port 25 using TLS.
And for another, it is sent through SMTP Server:
hotmail-com.olc.protection.outlook.com
Secured connection is on port 587 using TLS
And for all, I have checked:
Reply from the same address the message was sent to
All of those were set up as they were supposed to be when set up. It appears Hotmail/Outlook has been constantly changing the settings to use, who can keep up with it so many times! I haven’t used any of those others, only the one alias in recent times. One of the others, I see, it’s even called Testing, l guess for when I was testing things.
